| Notices |
#11 (permalink) |
5% Nation of
I would be highly interested.
under one condition... you rethink the whole coolant tank strategy. the WR tank needs a pressure releaf valve... I think you'll see why once you get some miles on it.
1994 Lincoln Towncar w/ 112576 1996 Contour SE MTX loaded w/ 134592 1999 Silver Frost ATX original owner w/ 70049 [in storage] "why buy it when you can build it for twice the price??!?!" Contour by day, Cougar by night. |
#12 (permalink) |
Buyer Beware
why dont you just say why instead of leaving us in mystery?
Originally Posted by Clutch "repost from turbomustangs thread, jesus can you not check the whole internet before you post something??? What the hell is wrong with you?" Parting out my cougar! "Square pistons rock..." -DemonSVT GMK full systems no longer available. GMK CAI Extensions available by special request only. |
#13 (permalink) |
It needs a relief valve because the radiator pushes water and steam in it as the car warms up. If the cap is sealed tight it will cause pressure in the overflow and not allow the hot coolant/steam to enter. The pressure must escape somewhere and could cause hoses to burst, leaks in the radiator, or blow cap off of over flow tank. It really depends on how much pressure is in the system though. If there is no pressure in the overflow tank it could cause all the coolant to flow out from radiator and coolant hoses into the tank (ie removing the cap when engine is warm). The system must be pressurized and create an adequate equilibrium depending on operating temp and pressures.
I'm sure the WR tank has some sort of relief in it. Perhaps on the cap like older radiators?
1999 Laser Red MTX 14.509 1/4 2.265 60' 2002 3L with SVT UIM, SVT LIM no secondaries, SVT Cams, SVT TB, 24# injectors, WR Headers & y-pipe, AEM Intake, SVT Clutch, Fidanza flywheel, Clevite rod bearings, ST200 valve springs, Underdrive pulleys, Escape oil pan, DMD, Magnecor KV85 Comp Wires, Polished timing cover-valve covers-MAF-TStat, Torsen LSD, Focus shift tower & forks, RP syncromax, SVT ECU, SCT Flip Chip, B&M Shifter, OMP FSTB, Mirko RSTB, Roush RSB, Roush Floor Mats, 2.5" Trubendz |
#14 (permalink) | |
5% Nation of
no there is absolutely NO releaf mechanism whatsoever... zero. and it builds up a tremendous amount of pressure. that puts alot of stress on the wields [which are good wields but nothing I would gamble my engine on] and the hoses... something is going to break. I'll post photos sometime this weekend but my WR tank is very bowed on top. previous owner had 1500 miles on it [and blew his engine], I had about 700 on it before I pulled it. there is also no way to use the coolant level sensor [its a float valve with the float mechanism built into the stock shell], so that sensor hole in the tank is pointless, and you have to deal with the coolant light permanently being on. also the tank doesnt have baffling on it... I dunno I could go on about this but when you break it down its a poor substitute for the stock one, and I didnt feel I needed to rehash this because its been covered lately in 2 other threads. combine all this with adding a significant amount of power to the system and your asking for trouble. [blackcoog, I love your work and your effort _and openness with sharing your buildup_ really is impressive. this has been my one and only complaint/concern... please dont take it as me trying to bust your balls]
1994 Lincoln Towncar w/ 112576 1996 Contour SE MTX loaded w/ 134592 1999 Silver Frost ATX original owner w/ 70049 [in storage] "why buy it when you can build it for twice the price??!?!" Contour by day, Cougar by night. Last edited by bensenvill; 09-01-2006 at 12:41 AM. |
#15 (permalink) |
I don't see the coolant light as being a big deal since you could easily fool the sensor and get the light turned off. Maybe you could even get it turned off with the SCT software? I don't know. It would be better if you were able to get the sensor into the WR tank, but I don't know if it is possible. I haven't torn into the stock tank or really looked at the sensor.
I also don't think that the baffles are a big deal either. Basically they would just keep the coolant towards the bottom of the tank more and keep it from sloshing around as much. The system only pulls in coolant from the overflow tank when cooling (car is off). Unless you park on a hill with the front alot higher than the back, it shouldn't pull any air into the system. If it does pull air in then the air should be forced back out after one or two cycles, maybe sooner. You could also keep the tank a little fuller to keep that from happening or perhaps even put a baffle inside it. The main thing I would be concerned about would be the pressure. If it doesn't have some sort of pressure valve then it would definately put a strain on parts of the system. Mainly the hoses, seems, radiator, etc. Excess pressure may even cause issues with putting a strain on the water pump since it would have a bigger force pushing back the propellers. I don't own a WR tank so don't know if it does have a pressure valve. I just didn't see why they would sell one without the valve. I will say unless those are really ****ty welds then the hoses would probably go before the tank does. You could always stick with your stock tank and move it or use another aftermarket coolant tank like James and KustomCougar did.
#17 (permalink) | |
The piping is another issue. Who is willing to hack into their car for that? It was two 3.5" holes and widening of the windshield washer tank hole.
#18 (permalink) |
Cougar Lover, Goat Raper!
Well, since we have to cut a whole just for a CAI, I don't think it would be a big deal for anyone serious about going FI to cut one more and enlarge another. Just as long as I know where to cut, I'm cool with it.
![]() 2004 5.7L M6 Black GTO 2006 2.0T DSG Candy White VW GTI 199 2.5L MTX Silver Frost Roush Cougar - SOLD 1999 2.5L ATX Rio Red Cougar - SOLD There is life after the Cougar, but the fast lane can be such a lonely place. ![]() |
#19 (permalink) | |
5% Nation of
ya I've been looking for a way to integrate a pressure relief valve... dont get me wrong, the tank has potental, but theres a number of issues I need to address with it before it ever goes back in my car. I have no problem drilling holes.
#20 (permalink) |
im looking to spend $2,000 -$2,500(not including a chip and tune) on my S/c setup. If you can produce a kit for something in that price range, with the fmic,bov,compressor,and piping.... i'll buy your product.
PErformance mods:GMK CAI, Msds headers, Level ten shift kit, TRUE dual exhaust system...no cats...flowmaster 40 series mufflers. Future mods: Level ten Shiftronic kit, 3l with svt cams and thomas knight(or hopefully Blackcoog) supercharger with all the goodies. |
