Metallic Single stage paint buff
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By rooster210
Thread: Metallic Single stage paint buff
    NECO Member LostOffspring99's Avatar
    2014 Jul
    East Palo Alto, CA
    935
    I've seen a lot of controversy on sanding and buffing metallic SS paint. Some people say you can, others say it makes the flakes uneven.
    What do you guys think?
    /oO___--___Oo\
    |=_/o____o\_=|
    NECO Member rooster210's Avatar
    2008 Sep
    Raeford N.C.
    1,988
    Re: Metallic Single stage paint buff
    I can find out tomorrow from an actual paint instructor whos been doing paint for over a decade if you want
    1999 frosty 3L MTX, A.K.A. "Jane", 1999 Ebony 3L MTX, A.K.A. "Luci"
    1999 E150 Econoline coachmen conversion A.K.A. "Pappy"
    1999 Honda Civic EX 1.6L Of Honda non turbo somethingness A.K.A. "Fairy Blue"
    2014 Jul
    East Palo Alto, CA
    935
    Thanks that'd be great!
    /oO___--___Oo\
    |=_/o____o\_=|
  5. Remove Advertisements
  6. #4
    2008 Sep
    Raeford N.C.
    1,988
    As long as there's enough material to buff without burning through the paint itself it should be fine according to what he said. He said the only real difference is the paint not having a base and a clear is thinner then regular. Buffing shouldn't mess it up.
  7. #5
    NECO Member whitecat99's Avatar
    2004 Mar
    Costa Mesa, CA
    492
    I would be concerned about exposing the metallic pigment. I think that would make it oxidize quicker and end up less shiny.
    White 99 Sport Cougar with 2.5L ATX - Purchased May 98
    Stock except for 16 inch Mangels chromed aluminum alloy wheels with 225-50 BFG g-force Sport-Z tires, K&N drop in filter and tinted windows.
    Wide open until you see God, then Brake!
  8. #6
    2008 Sep
    Raeford N.C.
    1,988
    The oxidizing part is normally the clear coat or lack there of. Its not because the weather got to the flake in the paint. Since single stage ia basically pigmented clear, if you have a lack of then you're down to sealer or bare metal.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  9. #7
    2014 Jul
    East Palo Alto, CA
    935
    Quote Originally Posted by rooster210 View Post
    Alrighty! Since Im for sure getting ss paint, I wanted to make sure I could sand and buff, I know dark metallic greys gonna look dope.
    /oO___--___Oo\
    |=_/o____o\_=|
  10. #8
    2008 Sep
    Raeford N.C.
    1,988
    Yeah it should look good. Just keep in mind it's not as thick a coating as traditional base and clear. It's going to burn through amazingly fast. The guy i asked i trust 10000% with any paint question after him being my instructor.
    LostOffspring99 likes this.
  11. #9
    2004 Mar
    Costa Mesa, CA
    492
    "The oxidizing part is normally the clear coat or lack there of. Its not because the weather got to the flake in the paint. Since single stage ia basically pigmented clear, if you have a lack of then you're down to sealer or bare metal."
    I was not referring to oxidation of the base polymer in the paint. In a single stage paint the metallic pigment is protected by a layer of the polymer. Back when they started using metallic paints, they were pretty much all single stage. Many of the metallic colors had problems with age. Silver was probable one of the worst. It the metallic pigment would oxidize in the polymer and the paint would become dull and start coming off. Once they learned how to formulate metallic paints, they more and more started going to two stage paints.
    Non-metallic paints work well in single stage but metallics are still suspect in my opinion, especially if they are going to be wet sanded and rubbed out.
