Go Back   NECO Forums > Chapters > Capital NECO
Old 12-27-2007, 11:12 PM   #31 (permalink)
Tigg's Avatar
Images: 10
Re: Engine codes
Yeah, mine would hit me in the head constantly. They were original though, so 8 years...
RJ, you could do it alone, but I promise it's much easier with someone to hold it open. They pop on and off better when the hatch is open completely.
~*~ Nicky ~*~
2000 Spruce Green v6 mtx ~ Tigg@CougarDB
2004 Twilight Blue 6MT G35 Coupe
Tweeter 3-18-77 ~ 7-9-03
Tigg is offline
Old 12-28-2007, 12:53 AM   #32 (permalink)
VADriven Member
Re: Engine codes
they are only bad in really cold weather. Otherwise they have been working well.
Topik is offline
Old 12-28-2007, 09:02 AM   #33 (permalink)
Capital Curmudgeon
skater's Avatar
Re: Engine codes
Originally Posted by DanG View Post
Does that awning hang at least? Maybe you told us already, but after that gawdawful welding job I did on it... I should try again- Now I have my MIG welder that can do aluminum... MUCH easier than TIG, but not nearly as precise as TIG can be...
Yep, the awning is working fine, not that I've had much chance to use it.
skater is online now
Old 12-28-2007, 07:01 PM   #34 (permalink)
12three45's Avatar
Re: Engine codes
Well my CEL came on again after a day of driving. Anyone have an idea what else besides the DPFE will cause the P0401? Last ditch will take it to the dealer. Have to get an emissions test in a couple months for the car registration.
Andy
99 V6 Silver
KKM
Yodude Y and Catback
12three45 is offline
Old 01-05-2008, 07:25 PM   #35 (permalink)
Re: Engine codes
Well actually I am dealing with the same problem. And so far I got it to go away for a little while by changing out the DPFE, then it came back and someone mentioned on here that I should go and clean out my throttle body.. sure enough the thing was clogged up like a Mother F#*^$ lol.. I have pics I will post. But yea that kept the code away for a good two months, but just recently It started to come back. So I think all the gunk got further down into my UIM or possibly down to the LIM >?
But anyways once I get that cleaned out somehow, I am hoping my new PCV oil catch system will keep this problem at bay for good :P
the TB before and after.. just shows how much crud actually makes it threw the PCV line..
New PCV oil catch filter I installed. These pics were taken after having it installed for only four days...
yea! I like going fast...
TheLastStand1984 is offline
Old 01-29-2008, 09:50 AM   #36 (permalink)
12three45's Avatar
Re: Engine codes
Thanks, I just might have to take the UIM off and clean the thing. I hear that it is not that hard to do. Do you need torque wrench to tighten the UIM bolts back on?
Any suggestions on cleaning the UIM? Or just clean the throttle body? Did you just turn the car on and used some kind of cleaner and sprayed it in?
Andy
99 V6 Silver
KKM
Old 02-03-2008, 07:44 AM   #37 (permalink)
12three45's Avatar
Re: Engine codes
Well, my EGR ports in the UIM was just as clogged up. Can't believe it could get that bad. Were you able to fix your engine code with the new PVC setup? I guess I need to start changing my PVC out every year just in case.
I'll do sea foam with my next oil change to hopefully force the rest of the gunk out.
So far so good, no engine light. Now just have to drive 100 miles so I can get my emissions test and get my registration renewed.
Andy
99 V6 Silver
KKM
Old 03-19-2008, 10:09 PM   #38 (permalink)
Re: Engine codes
I have a p0125 a p1000 and a 1602???
are these serious enough to see a mechanic? or will it work itself out?
I have plenty of coolant...
also what might all of this mean?
CheeseEater88 is offline
Old 03-19-2008, 11:45 PM   #39 (permalink)
DanG's Avatar
Re: Engine codes
Cougar 101.
The 0125 means you have a defective ECT sensor or your thermostat has gone bad (i.e. always open, engine never heats up).
The 1602 I actually had to Google:
Ford OBDII Powertrain Diagnostic Trouble Codes P1500-P1699
P1602 Immobilizer/ECM comms error
Never seen that one. Clear it, see if it comes back... If so, may have bad ECU/immobilizer, or the RFID chip in your keys may be defective or not being read right by the computer.
Dan G.
DanG is offline
Old 03-20-2008, 12:25 AM   #40 (permalink)
Re: Engine codes
I assume its okay to drive on... I won't have time to take it to the shop for till saturday
and thank you...
and is there a better thermostat/waterpump than stock...? I've had problems with the cheap plastic
