Old 05-20-2006, 03:25 PM   #1 (permalink)
azervas's Avatar
Engine Start Button
S2000 Style apparently!!!
Been hard at work for a couple of hours today doing this!!
Looks pretty sweet!!!
Going to wire it in tomorrow/monday!
azervas is offline
Old 05-20-2006, 06:47 PM   #2 (permalink)
scrupul0us's Avatar
Images: 12
Re: Engine Start Button
looks clean so far... does it light up?
scrupul0us is offline
Old 05-20-2006, 07:13 PM   #3 (permalink)
azervas's Avatar
No it doesnt light up!
azervas is offline
Old 05-20-2006, 07:28 PM   #4 (permalink)
MercCoug99's Avatar
thats awesome.
MercCoug99 is offline
Old 05-22-2006, 02:41 AM   #5 (permalink)
is now available in HD
Tygerr's Avatar
Awesome.
Buckeye @ heart
06 Legacy 2.5i Limited
Tygerr is offline
Old 05-22-2006, 11:06 AM   #6 (permalink)
Audiobahn Abuser
blustreak's Avatar
looks nice. Anyone have info on how to wire one of these up? I already have remote start from my alarm on my MTX so I assume I could tap into one of those wires some how.
WTB: Vortech Spec MSDS Headers : Front Adjustable Koni's : Good condition Stock MTX Shift knobs : 3 gauge Pillar pod : 4 gauge Airbag pod
FS: New WeaponR Headers & Y : COP set : Walbro 255lph fuel pump : Cougar S CF Hood : 2 Pillar gauge pod - LSB : Razzi High Rise Spoiler - Silver : 19" Icon W64's w/ Toyo Proxie4's : Misc 3L Parts : +more just ask if I have it
cougardb
Like to travel?
blustreak is offline
Old 05-22-2006, 11:08 AM   #7 (permalink)
Karma just kicked ass
wadespencer99's Avatar
Images: 7
Found Push Button Starter How-To:
First and foremost, you have to get past the fact that you won’t have a cigarette lighter anymore, and will not be able to put it back in. From what I could see, the lighter is molded into the plastic piece underneath the nice trim and you need to Dremel around it to get it out. So with that out of the way…
1. Remove ashtray and little trim ring from around the lighter, it should pull off with some gentle pressure.
2. With a Dremel tool CAREFULLY Dremel around the lighter. IMPORTANT: IF YOU GO TOO FAR TO THE PASSENGER SIDE YOU WILL CUT THE SUPPORT FOR THE TRIM RING AND IT WILL JUST FALL OUT WHEN YOU TRY TO RE-INSTALL IT! Dremel out enough for the back of the button to fit.
3. I used the Arogear Euro Type-R Button, which is the direct replacement for the S2000. It fits very nicely in the trim ring. Look for it on eBay. I got mine cheap.
4. Install the button in the trim ring.
5. With all that done, you need to work on the wiring.
5a. The button came with a relay with 4 wires in the relay and 2 off the back of the button. All the button essentially does is throw a ground.
5b. One wire off the back of the button needs to be grounded; I found that the ground for the lighter was the strongest around. It’s the white/blue wire. The other wire connects to the relay.
5c. Next you need to remove the panel off the bottom of the steering column, its 3 torx screws.
5d. Under the panel you will see a brownish cap on the back of the ignition, from that is a group of electrical taped wires, carefully cut away the tape exposing the wires.
5e. You are looking for 3 wires: Red-12v from battery, Gray/White-to the starter coil, and Yellow/Green OR Yellow-the ACC position of the ignition switch. (the ACC wire in my 99 ATX was solid Yellow)
5f. I used quick connect piggy-backs for a nice quick and reliable connection, since it doesn’t involve cutting any wires. Connect up all the wires according to your button’s instructions and you are good to go.
6. Now, if you cut the Gray/White wire from where you piggy-backed to the ignition, you will disable the start position of the ignition and only be able to use the button (you will still need the key, however). I didn’t do this, but if you like yours enough, I thought I would let you know how to do it.
From TeamNECO.com
CFX 1st Place Mild
wadespencer99 is offline
Old 05-22-2006, 11:48 AM   #8 (permalink)
azervas's Avatar
Thanks Wade!
azervas is offline
Old 05-22-2006, 12:48 PM   #9 (permalink)
Basilisk
LostRacer's Avatar
Nice..I have mine located next to the cupholder. And the Engine Start lettering lights up
The One&Only!
C.A.R.B # FU50
XBL=LostRacer2
PSN=LostRacer
LostRacer is offline
Old 05-22-2006, 04:12 PM   #10 (permalink)
Excelcier Strikes Back
Excelcier's Avatar
I could light that thing up!
The Faster car is HALF mine!
NECO's official pace car
http://excelcier.com
Excelcier Headlight Flashers
Are you ready to join the movement?
Excelcier is offline
