#11 (permalink) |
Re: Dimming/Pulsing Lights FAQ/Overview STICKIE PLEASE
Great thanks.
Maybe you should get the Admin to see if they can host those pics on here. I notice alot of pictures disappear on this site after a while. And this is a must have. |
#12 (permalink) |
Did this on the weekend and WOW what a PITA if you have sausage fingers/hands....
I ended up breaking the grey clip and fabing up a new clip. I'd recomend doing this when replacing the alternator... |
#13 (permalink) |
Sami is watching you.
May I ask what the point of taking the small single wire connector off is?
EDIT:: just kidding. so you can pull the clips up top for easy wire modification. lol yes george, i know im retarded. |
#15 (permalink) |
So, my cougar has been dying on me occasionally after coasting for a while, or just randomly at the occasional stop light. Some times the interior lights just dim a little and the engine almost quits then revs itself. Just tonight I put a volt meter on there and it sat at 14.1 when running if I gave it gas or not. Dropped off to 13.5 or .4 when the car was off. So is it time for a alt replacement, or just the crappy wires and the cold weather in WI effecting it? thanks
#16 (permalink) |
Ummm... Voltage should only be sitting at 12.6???? And that's fully charged.
2000 Cougar 2.5L V6 MTX Mods: MSDS headers and Y-Pipe (High temp Ceramic coated), Trubendz test pipe w/ high flow cat, 2.5" SS Trubendz Dual exit exhaust w/ Borla muffler |
#17 (permalink) |
Hmmm my ALT has been replaced 2 times now and my powercap says I'm runnig 14.2 amps?? but I'm runnig the biggest ALT I can fit in it, Is that normal If not maybe I should do the re-wire.
http://www.myspace.com/kwg2371 If your cougars not broke, you are. If your going to sell somthing POST your price and location |
#18 (permalink) |
Is moving.
![]() Join Date: Aug 2004
amps or Volts? thats a normal voltage for a running car. Thats a serious issue if its amps.
If so its likely you blew your alt fuse or something else is wrong. Oh ya and i still strongly suggest not doing this mod in this fashion. It makes no allowances for load, and is not a propper fix. Though i do agree a new sensing wire needs to be run, i dont feel this is a good location, only an easy one.
In wine there is wisdom, in beer there is freedom, in water there is bacteria. -Ben Franklin |
#19 (permalink) |
Oops I ment volts
#20 (permalink) |
alright, i read through the 15 pages How To: Fix dimming lights/gauges
then finally found pics in this thread! i have this problem on my '02 and there was only one post about an '02 in all of this. i haven't looked at my wiring yet but has anyone had this problem or done this fix to an '02? i read there is only 2 wires in that connector, i'm hoping that one is red.. |
