How to make fronts and rears louder?
I have MB Quart 5.25" components up front, infinity kappa 5x7's in back. The MB Quarts arent rated very high as far as power handling and will be replaced soon, but a question on the rear - The infinitys are rated at 100w rms. Now I have an alpine 2 ch amp powering the kappas, the amp does 50w rms. Now I know thats not full capacity and also I know more power less distortion usually, but when I hooked up the amp, I only have my gain setup a little below the default, anything higher and it distorts? Can anyone tell me whats up? Is it just the case of still too little power?
Thanks for any help.
1999 Silver Frost 2.0L MTX - Ford Racing Head, Optimized TB. CTA Intake, Crower Stg 2 Cams, ZXTuner Header, Trubendz Exhaust, Spec Stg 2 Clutch, Roush Springs, Roush Rear Sway, Filled Motor Mounts, Ford Racing Wires, Roush Body Kit, Roush Spoiler, 01/02 Grille and Headlights, Vis OEM CF Hood |
RE:How to make fronts and rears louder?
all speakers are amped now, deck doesnt put out any power now.
Basilisk
RE: How to make fronts and rears louder?
you can try adjusting the gain to match te output voltage of your deck(most are 2 volts) Then try tuning it. Before you go adjusting the gain make sure your levels are all at 0. Bass 0 Treble 0. That way you have a base to work from once you get started. For more info, try doing a search for amp setup or gain matching..I kow there were some discussions over the last 6 months on ths.
The One&Only! C.A.R.B # FU50 ![]() XBL=LostRacer2 PSN=LostRacer |
