car battery shelf life
Results 1 to 8 of 8
Thread: car battery shelf life
    3 wheelin Lifetime Platinum MemberSuper Moderator jaged's Avatar
    2003 Mar
    hebron, in
    21,205
    How would a yellow top be affected if it had beed sitting for 2 yrs in a cardboard box. Im unsure if there was a charge on it or not. Would the charge capacity be affected? Or the ability to hold a charge at all?
    '14 Fusion SE Ecoboost daily driven kid hauler
    '01 2.5 mtx (parted 3-28-14, scrapped 9/11/16)
    '99 3L AutoX
    '08 Mustang Bullitt #5389 4/12/13 sold to B3NN3TT
    Excelcier Strikes Back Moderator Excelcier's Avatar
    2002 Apr
    at my house
    5,421
    RE:car battery shelf life
    Optima's have an internal resistance and they will drain completely in about 2 weeks if you leave them, maybe a month on a shelf if it's not connected. Just charge it up and go!
    The Faster car is HALF mine!
    NECO's official pace car
    http://excelcier.com
    Excelcier Headlight Flashers
    Are you ready to join the movement?
    NECO Member whitecat99's Avatar
    2004 Mar
    Costa Mesa, CA
    489
    All batteries have internal resistance. It is my understanding that Optima batteries have lower internal resistance than conventional batteries. Optima batteries can hold a charge for a long time on the shelf. They claim you can leave them on the shelf for a year before they need to be recharged. Yellow top batteries are a deep cycle type and it will not hurt to completely discharge them then recharge them. They are made to stand up to that type of use. The Red Top on the other hand likes to have its charge maintained but will resist being near complete discharge better than conventional batteries. Just charge your Yellow Top and use it. It is recommended to charge the Optima with a specific type of charger. I do not remember what they are called but most modern chargers are suitable.
    White 99 Sport Cougar with 2.5L ATX - Purchased May 98
    Stock except for 16 inch Mangels chromed aluminum alloy wheels with 225-50 BFG g-force Sport-Z tires, K&N drop in filter and tinted windows.
    Wide open until you see God, then Brake!
    NECO Member Crispy's Avatar
    2000 Nov
    Wisconsin
    10,831
    RE: car battery shelf life
    well I recently had a Optima Yeller top crap out on me... it was in my car less than 2 years and sat on the shelf prior at a store for over 1 year... warranty was over so I was out the battery... I bought a red top to replace it and waited on a list to have one sent to me as soon as it was produced.. it was only DAYS old when I got it..
    bottom line is how it was charged once it was bought.. the item needs to be on a very very low trickle charge for about 24 hours prior to installing.. if you buy the item from someone who does not initially charge this way you will most likely have it's life ended prematurely like mine was - hense the reason why I bought from a reliable source and bought a fresh battery so I would have the entire warranty period.
    '02 VF34 2.0 Turbo Subaru WRX -- STAGE 2+
    '08 Dodge Nitro --
    See My PREVIOUS Rides
    NECO Member h8beingbored's Avatar
    2003 Sep
    Yorba Linda, California
    1,616
    . . . the yellow top is the one most used for cars with sound systems right? i need to get one soon . . .
    2000 Nov
    Wisconsin
    10,831
    the yeller top can take more abuse than a red top but keep in mind that the yellow top only has a 1 year warranty and the red one has 3 years with a portion prorated but its alot longer than the yellow ones
    '08 Dodge Nitro --
    2003 Sep
    1,616
    so i should go with the red top?
  9. #8
    2004 Apr
    57
    Originally posted by: Excelcier Optima's have an internal resistance and they will drain completely in about 2 weeks if you leave them, maybe a month on a shelf if it's not connected.
    You're thinking of dry cell batteries. Optima's are very different.
    Jaged,
    Since you already have a yellow top, go ahead and charge it up and use it. Normally you would want to use a red top Optima. The yellow is DEEP CYCLE. So unless you run a lot of lights and amps <u>with the engine off</u>, it's not the best suited battery (but still better then your standard car battery). If you look at Optima's web page, the technical specs show the red top's performance is better as it's designed for normal car use.
    I run red tops on both my cars and they work just fine. Plus I saved a few dollars by not getting the yellow tops!
    2005 Mini Cooper S Supercharged I4 MTX Red
    1981 DeLorean V6 MTX Stainless Steel!
    2000 Cougar V6 MTX White - traded in
  1. Tires have a shelf life ... that means that they expire!!!
    By FastCougar in forum Wheels,Tires & Brakes
    Last Post: 2009-02-08, 04:17 PM
  2. Third Annual Rides for Life Car Show 9/23
    By MattyD879 in forum Gotham City NECO
    Last Post: 2007-09-24, 01:58 AM
  3. Real life NFS Police car
    By screenamesuck in forum Garage Talk
    Last Post: 2006-06-04, 06:57 PM
  4. Battery Life/IAVC Fix
    By Cougarkid in forum 2.5L DURATEC Performance
    Last Post: 2006-04-05, 11:10 AM
  5. Battery Life
    By Croat23 in forum General Info
    Last Post: 2005-02-23, 06:36 PM
