Old 06-21-2004, 02:20 AM   #1 (permalink)
New custom stereo install!!! Check it out!
I have been working long and hard on this... It has taken about 2 and 1/2 weeks from start to finish - but I have been doing it at my leisure in my free time. It isn't quite finished yet, but there is only one more board to build. What still needs to be done is this:
1) Build a board that goes in front where the open boards are now. The board will go down to the floor, and will meet up with the board that the nitrous is mounted in.
2) Mount lights inside the ZEX and N2O windows, and in the sub and amp window. There will be blue neons inside the windows with the carvings. They will be mounted behind the carved board so that when lit, you will see an illuminated "ZEX" and N2O." There will also be blue neons inside the sub and amp window.
That's it! I'm almost done! Woohoooo!!!!!! Anyways, here are the pics....
Gee officer... I thought that the speed limit was 100. OH! That sign said highway 100??? Oops.
Check out my CarDomain page... Sign the guestbook please!
ZEXCougar is offline
Old 06-21-2004, 02:38 AM   #2 (permalink)
Ness1216's Avatar
RE:New custom stereo install!!! Check it out!
Looks really really sweet. Good job!
1999 Silver Frost 2.0L MTX - Ford Racing Head, Optimized TB. CTA Intake, Crower Stg 2 Cams, ZXTuner Header, Trubendz Exhaust, Spec Stg 2 Clutch, Roush Springs, Roush Rear Sway, Filled Motor Mounts, Ford Racing Wires, Roush Body Kit, Roush Spoiler, 01/02 Grille and Headlights, Vis OEM CF Hood
Ness1216 is offline
Old 06-21-2004, 04:01 AM   #3 (permalink)
RE: New custom stereo install!!! Check it out!
Nothing like a nice clean trunk with all the goods displayed from inside! Good job!
Mazda 3'n around town now-
Last I heard the cougar was rolled into a sand dune.....should of kept it.
Lukydogg is offline
Old 06-21-2004, 10:00 AM   #4 (permalink)
I like that a lot. Looks very clean! I'd much rather have a nice clean look like yours than a bunch of flashy looking fiberglass enclosures.
2002 Camaro Z/28, LS1, 6-speed, SS hood, Hurst Shifter, LSS, !Cags, FTRA, Cat-back, '69 Z/28 emblems
1978 Trans AM, 400, Hurst 4-speed, W72 "being restored"
1999 Mercury Cougar, V6, 5-speed
chadds is offline
Old 06-21-2004, 11:08 AM   #5 (permalink)
Nitrik's Avatar
Looks really nice and clean, lights should add a nice touch. Good job man!
Now, what do you have planned for the trunk?
NEW: 2009 Dodge Caliber 2.4L Turbo SRT-4
OLD: 2000 Mercury Cougar 2.5L V6
CougarDB.com
Nitrik is offline
Old 06-21-2004, 12:13 PM   #6 (permalink)
I have been tossing around a few ideas... If I do anything to the trunk, it will be this:
Make a board that sits about 2" in front of the current back board. Carve a big cougar head into it and plexiglass behind it. Add a blue neon so the cougar head glows. Then build out the sides and put a window in each one. Through the windows, you will be able to see the battery on one side, and two crossovers on the other side. This would be lit in blue neon as well.
That is if I end up doing anything to it... I kind of like the trunk the way it is for now. I just built a new floor for it, and have it split into 3 sections and hinged so I can get to my spare if needed. It's kind of nice to have the storage back there, so I think I may leave it. I'll decide on that later though. I think that the fact that I am simply sick of working on it after 3 weeks is making a huge impact on me wanting to start on the trunk!
Old 06-21-2004, 12:40 PM   #7 (permalink)
Basilisk
LostRacer's Avatar
Very nice. How big is the enclosure for your L5?
The One&Only!
C.A.R.B # FU50
XBL=LostRacer2
PSN=LostRacer
LostRacer is offline
Old 06-21-2004, 12:54 PM   #8 (permalink)
I made it .3 cubic feet larger than the box it came in from Kicker. It is a total of 2.3 cu ft. I wanted it to be a bit larger to give me some more bass, but not too large to effect sound quality. It actually turned out pretty nice. It sounds great!
Old 06-21-2004, 03:25 PM   #9 (permalink)
19-17-4
ND4SPD's Avatar
cleanest trunk i've ever seen [img]custom_images/emoticons/shocked.gif[/img]
~Matt~ ND4SPD Army Kommandant
Amanda and I now has THREE penguins!! ...somewhere.
Dude... brain first, post second.
ND4SPD is offline
Old 06-21-2004, 03:53 PM   #10 (permalink)
VHull03's Avatar
looks really great. i just think itd be hard to not have a backseat, but i guess youd get used to it. only thing... is there as much difference in real life with the colors of the carpet you have and the stock trunk carpet as shown in the last pic? cuz i can definitely tell a difference between the "seat back"/floor compared to the sides.
VHull03 is offline
