I am trying to install my aftermarket headunit, now I've already got all the how to's and bought everything I need.
I am removing the stock 6 disk in dash unit and there are 2 plugs, I have supposedly the right adapter, it has one connector, it fits in the black harness perfectly. I don't think I have the premium system as there is no separate amp.
The other factory plug has only 1 wire leading to it. (is this for the CD changer?) When I connect everything I have no power...
I think it might just be that I need to run a ground wire from the aftermarket unit but I wanted to check first as I am a little afraid of shorting something out.
Any advice greatly appreciated.
LinkBack URL
About LinkBacks
