anyone?
You don't want to use the audiobahn subwoofer with that amplifier, unless you are going to wire the voice coils in series (for a final impedance of 8 ohms). It's a DUAL VOICE COIL subwoofer and the subwoofer channel on that amplifier is only rated for 4 ohm loads (or higher).
My personal opinion is to either stick with the Pioneer subwoofer or find a different model of the audiobahn subwoofer that has either a SINGLE VOICE COIL or is a DVC with each coil having an impedance of 2 ohms.
