will this head unit work in my cougar?
Results 1 to 4 of 4
Thread: will this head unit work in my cougar?
    NECO Member cougarboy91's Avatar
    2008 Apr
    Toronto, Ontario, Canada, 110941395597405, Toronto, Ontario
    374
    i have been looking for a in dash head unit please let me know if this will work or will i need to go bigger thanks.
    Pioneer 5.8" In-Dash Double-Din Car Video Deck With Bluetooth (AVH-P3300BT) : In-Dash & Overhead Car Video - Future Shop
    99 cougar.2.5 mtx. black. trubendz dual borla. roush lowering springs. Roush kit. B&M short shifter. v-tech light covers. 2 channel rockford fosgate 100.2. pioneer gm2000. sony cdx630ui. 5x7 blaupunkt speakers. ford grill. clear side markers.
    NECO Member Gold Member StuartGrant's Avatar
    2009 Jul
    Mt. Clemens, Mi
    1,503
    Re: will this head unit work in my cougar?
    You will need to go smaller unless you've swapped in a 01-02 interior, even then I think there's some modification needed to get a double din radio to mount properly.
    00' MTX 2.5L, spruce green: Died 9/13/11 - Revived 6/1/12
    10/10 Lifetime Platinum MemberAdministrator wadespencer99's Avatar
    2003 Oct
    Wellsboro, Pa
    14,834
    A double-din fits with the 01/02 radio/hvac bezel, but some dremeling on the bezel is still required. I'm pretty sure some thread have been posted up detailing what needs to be done.
    1999 Cougar - 2000 original Roush Cougar - 2004 F150 FX4 Supercab
    NECO Member Tumuerte's Avatar
    2010 Oct
    Windsor, Ontario
    983
    I was in your spot back in February and came around asking. I installed mine due to the great information and advice found on these forums.
    Here is my thread in this matter:
    Pro Installers, need help installing JVC KW-NT3HDT
    My head unit didn't fit even after being able to make it past my bezel due to a small "U" shaped guide bracket for the stock unit. I ended up dremmeling the two rivets holding it to the dash off and it fit perfectly. Read up before you act.
    * 2000 V6 MTX (Black), MSDS Headers + Y-pipe, K&N SRI, Trubendz-Borla, HMS, Torsen, Stage 3 Clutchmasters, Fidanza, 8k's x4, JVC KW-NT3HDT, '01 leather interior
    * 1999 V6 MTX (Silver Frost), Lincoln Sync Nav system
