Obey
Re: pioneer head deck flipout?
They do that to remind you to remove it for security reasons. Pop it off and put it in the case and toss it in the glovebox if you don't want to carry it. My 6800 does this.
Skolenimation: Graphic Design | Modifications @ CougarDB.com | NEW! Flickr Account ![]() "In the beginning of a change, the patriot is a scarce man, and brave, and hated and scorned. When his cause succeeds, the timid join him, for then it costs nothing to be a patriot." - Mark Twain |
Coming for you...
they used to have a menu you could access with the deck turned off that you could turn this off... check out your manual
-Dan MetalDamage!!!! The beatings will continue until moral improves!!! <--- Classic!!!
is now available in HD
^ Agreed. Use your manual. You can turn it off. If you dont' have your manual you can download it from the Pioneer website.
Coming for you...
because I was bored and it took me all of 7 minutes:
Taken from pg 53 of your manual Setting the automatic opening function The automatic opening function opens the front panel to remind you to detach it. (Refer to page 11.) You can turn the automatic opening function on or off. 1. With the source turned off, press and hold 1. 2. Press NEXT and then press DT-OPN to select the automatic opening mode. 3. Press DT-OPN to turn the automatic opening on. ON appears in the display. Press DT-OPN again to turn the automatic opening off. your manual is available here if the direct link doesn't work, here's your deck on the pioneer website
