Chairman of the Bored
Re: testing a deck
You should be able to test if it will power up just by using the power and ground but, of course, you won't be able to tell if the speakers or anything else works.
1997 Cadillac Catera - me 2009 Hyundai Sonata - wife |
Re: testing a deck
I have in the past tested them using a battery charger set on its 10A charge mode. Just hooked the red and yellow to the positive and the negative to the negative.
Re: testing a deck
You should be careful hooking it up without speakers connected, that is a good way to blow a channel out on it. If you connect it and turn the volume up without speakers it could possibly fry it. I would connect two speakers up to it and twist the yellow/red together and stick it to the positive (+) on the battery and stick the black to the negative (-) on the battery and test it that way. Make sure no other bare wires are touching
#5 (permalink) | |
Merry Christmas!
Re: testing a deck
As stated: yellow and red to positive and then ground should net you an on result. Now with out any speakers co9nnected you won't know if anything else is functioning correctly 9internal amp).
The One&Only! C.A.R.B # FU50
Re: testing a deck
humm only flaw? considering that you are going to be connecting to the radio to your factory wiring when you install it and also the fact that not all radios have rca outs then I believe you would be using speaker wires.
#7 (permalink) | |
Merry Christmas!
Re: testing a deck
in our cars the stock speaker harness is seperate from the power..![]()
