Old 08-17-2008, 09:18 PM   #1 (permalink)
Megalo's Avatar
It's time for a high output alt
So the time has finally come for me to get a new alternator. I got this Cougar new in Sept. 99, & its is still on its first alt. I have been running a Eclipse XA4000 4 channel amp & a HIFONICS BXi2006D 2000W mono sub amp for a couple of years now.
I have to turn the music down @ idle, or I'll end up with a dead battery fast. But all in all the stock alt has been able to keep up with my stereo. So now it’s dead & I have a reason to upgrade.
I have a few questions…
1. How many amps do I need? 200 amp or 300 amp? (see amplifiers above)
2. Where should I buy a high output alternator?
3. Is there a power wire that goes straight from the alt to the positive post of the battery? Or does it go through the fuse box or something?
Thanks a million!
Pioneer Premier DEX-P1R / Rainbow Profi Kicks / Eclipse XA4000 / Alpine Type-R 12" x 2 / Hifonics Brutus BXi2006D
Megalo is offline
Old 08-18-2008, 12:43 AM   #2 (permalink)
kwg2371's Avatar
Re: It's time for a high output alt
220 worked for me and I'm running a little over 3000 watts . I got mine from DB electrical and love it, you'll need to get new wiring for the ALT.
the alt and wires ran me about $300 bucks
The cable runs from the battery to the starter to the alt
PS a new optima yellow top battery helps 2
http://www.myspace.com/kwg2371
If your cougars not broke, you are.
If your going to sell somthing POST your price and location
kwg2371 is offline
Old 08-18-2008, 12:45 AM   #3 (permalink)
Megalo's Avatar
Thanks! Yea I currently use an Optima Yellow top. B1tch has been drained down to nothing & back more times than I can remember in two years, & its still going strong! I think I'll try a kinetik when I finally do kill this Yellow Top though. They seem to fit alot more amps into a smaller package.
Megalo is offline
Old 08-18-2008, 09:39 PM   #4 (permalink)
Megalo's Avatar
This looks really good
http://cgi.ebay.com/ebaymotors/Couga...mZ370072786154
& the new wires & fuseblock to go with it:
http://cgi.ebay.com/ebaymotors/FORD-...mZ140258495429
What do you think?
Megalo is offline
Old 08-18-2008, 10:03 PM   #5 (permalink)
Coming for you...
ice992's Avatar
Images: 30
that alt, yes... the power kit, sure if you don't have any of that laying around... I'd use higher quality wire, looks to be "generic" wire... But, I could be wrong...
When I did the big 3 and the alt in my coug, I ran Kicker Hyperflex 1/0 (yes, overkill lol) I beleive i still have an entire roll of it, and a roll of 4 ga too come to think of it
-Dan
MetalDamage!!!!
The beatings will continue until moral improves!!!
<--- Classic!!!
ice992 is offline
Old 08-19-2008, 03:47 AM   #6 (permalink)
kwg2371's Avatar
lol thats the same alt and wiring kit I got
kwg2371 is offline
Old 08-21-2008, 04:35 PM   #7 (permalink)
Thumbs up Re: It's time for a high output alt
Wow thanks this thread has just helped me out.
speed-demon is offline
Old 08-26-2008, 06:49 PM   #8 (permalink)
Megalo's Avatar
Well I installed the new alt. I upgraded the wires to 4 gauge and added a 250 amp fuse. Things were working fine for ~ 10 miles then the fuse blew. I was cranking the stereo pretty hard. I don't know if that’s why it blew. I can’t find 250 amp fuses here locally, so I ordered a 250 amp circuit braker.
Anyway, cars dead again ... for now.
Megalo is offline
Old 08-26-2008, 07:06 PM   #9 (permalink)
Merry Christmas!
LostRacer's Avatar
Check your wiring. The fuse shouldn't "Just blow". Make sure you're not shorting somewhere.
The One&Only!
C.A.R.B # FU50
LostRacer is offline
Tags
alternators, high output
