so I'm going to put some white LED's in the coog that are going under the kick panel, glove box and inside the cd bracket.
they are each single LED lights that have to be wired together and I'm not sure exactly how to do it It gets hooked up to 12v hot wire then needs to be grounded, Does anyone know wich wire on the cig lighter is the 12v and ground? and I will be putting a toggle switch in will it need an inline fuse if so how much amp should it be thanks kyle
http://www.myspace.com/kwg2371 If your cougars not broke, you are. If your going to sell somthing POST your price and location |
Banned
Re: A little help with L.E.D's
generally red or yellow is going to be hot wires, and brown or black will be ground.. best bet is multimeter just to be safe. i did some blacklights from a computer under my dash, and just T-tapped into my CD player's memory wire, it's 12v.
