Quick question about subwoofers and amps...
Alright, here's my deal... I have 2 ten inch rockford P3's, (400 watts RMS, 800 peak) and they're both being pushed by a kenwood KAC-7204 (bridged at 4 ohms, putting out 500 watts rms)
Kenwood KAC-7204 2-Channel Car Audio Amplifier So, I realize i'm underpowering my subs, and i'm also trying to pull too much from that amp, because it's overheating and going into protect mode, then coming back on a few minutes later once it's cooled. I'm thinking about buying another of the same amp, and wiring one sub per amp. That *should* fix my overheating problem, as well as making the subs run louder, right? or wrong? (i also have a SWX 1 farad capacitor installed, i don't think it matters, but i'm saying it just in case) Thanks in advance, -Chris (edit) Also, if i did this, i would have to wire each sub to an 8 ohm load, and the amp would see it as a 4 ohm load? The amp is stable in 4 ohms when bridged Last edited by lazybum; 07-23-2008 at 05:53 AM. |
Re: Quick question about subwoofers and amps...
If the amp is overheating from driving your subs that means either its not cooling properly because there is no airflow or more likeley that you have your gain set too high and its causing clipping (gain is usualy not set much more then 50% of max) If the settings are set properly underpowering subs shouldnt overheat an amp.
your wiring should look like this correct? ![]() try turning down the gain a bit and see if it solves the issue. the subs wont be as loud but they also wont be distorting and it will be easier on the system as a whole.
I would actually recommend getting a more powerful class D (mono) amp for the subs and use the amp you have to power some good speakers. that would make for a full system and your subs wont drown out your actual music. I just ordered an Phoenix Gold Xenon 600.1 amp for 250 bucks plus 40 shipping (20 in the states) its rated for 600w rms but is known that they do at least 800.
to answer your question tho, yes a second amp could improve sound but I dont know how you would wire it, there is not a rating for bridged 2 ohm operation on that amp so it probably wouldn't be able to handle it; and individually you can wire each sub to only 2 ohm or 8 ohm loads. and wiring each individual voice coil to a channel would still give an 8 ohm load at 8 ohms you would probably see a minimal difference because the amp will actually put out less then its rated power. Overall its just not optimal to run 2 of those amps to 4ohm dvc subs. if they were single 4ohm or dual 2ohm you would be able to get the full power out of the amps.
![]() http://www.cardomain.com/id/BergsMach Roush Kit/ Halo's/VVME/ SRI/ 18" BSA Rims/PG X600.1/RF P2002/ 2 12" MTX MXS1204's/ Infinity 5X7/ FocusSport UDP/Intrax/ ST200 Last edited by iceberg65; 07-24-2008 at 02:12 AM. |
This is the amp I'm looking at... Good amp?
Kenwood KAC-9104D (kac9104d), Car Amplifiers, Mono Subwoofer Amps - Sonic Electronix And that should power the subs just fine if i run them at 2 ohms, right? I don't wanna blow the subs, so i don't think i'd wire at at 1 ohm, seeing as the subs peak power is 800 watts edit: and just as a little add on to my message... Thanks to everyone on this site that's helped me the past few times i've asked for help. You guys are really nice people. I went to other electronics sites and people acted like i was stupid. Just wanted to say that. Last edited by lazybum; 07-25-2008 at 01:31 AM. |
looks to me like that amp would do the job, kenwood doesnt have the best name for quality car audio stuff but thats a nice price for an amp with those ratings and kenwood has been around for a long time. Go for it and grab some good speakers to run off that other amp. amplified speakers make a world of difference. when you get everything set up make sure to post pics in my audio system thread.
did turning down your gain solve your overheating issue? Ive been on car audio forums too and the people there make me feel like I know next to nothing bout car audio. There is so much to know my knowledge pretty much scratches the surface. I think the most knowledgeable car audio guys on newcougar that come to my mind would be excellier and ice992
![]() http://www.cardomain.com/id/BergsMach Roush Kit/ Halo's/VVME/ SRI/ 18" BSA Rims/PG X600.1/RF P2002/ 2 12" MTX MXS1204's/ Infinity 5X7/ FocusSport UDP/Intrax/ ST200 Last edited by iceberg65; 07-25-2008 at 03:34 AM. |
Yea, i just realized that that amp puts out the same bridged at 4 ohms as my current amp. And my subs are 4 ohm DVC, so I can't put out a 2 ohm load. Oops? I really need to start paying attention. Aug. In any case... I came across this
Power Acoustik OV1-2000D (ov12000d), Car Amplifiers, Class D Amplifiers - Sonic Electronix So I'm probably gonna end up getting that instead. Last edited by lazybum; 07-25-2008 at 06:31 AM. |
#10 (permalink) |
just wire them to 1 ohm
![]() as long as the gain is set properly your subs will be fine. rockford subs should be able to handle some extra power over what its rated.
