Old 07-03-2008, 12:49 AM   #1 (permalink)
Chairman of the Bored
thousandlegs's Avatar
Keyless Entry Keypad On Door
Hey gang. I've searched around and haven't found anything so here's the ask:
Do any of you know if there is a way to retrofit one of those numeric keypads on the door to lock and unlock and open the hatch? My wife's Mountaineer has one and it's pretty darn handy.
1997 Cadillac Catera - me
2009 Hyundai Sonata - wife
thousandlegs is offline
Old 07-03-2008, 01:33 AM   #2 (permalink)
Calendar Lady
Goldie's Avatar
Images: 174
Re: Keyless Entry Keypad On Door
I believe it was a dealer installed option (but in all the time I've been around here, haven't heard of anyone with it). check with your ford parts counter.
Goldie is online now
Old 07-06-2008, 01:28 AM   #3 (permalink)
Hi thoudandlegs. Like Goldie stated, your best bet is probably to ask the Parts Department Staff at your local Lincoln-Mercury of Ford Dealer.
You might want to ask the Parts Department Staff is this one will work: Part # 7L2Z-14A626-BA. It is the latest model for the Mercury Milan and other current vehicles. You can see it here, at this link: http://www.mercuryaccessories.com/fas/b2c/catalog.asp Click on "Electronics" on the left side. Then "Keyless Entry Keypad". Then "Keyless Entry Keypad" again. As long as the frequency ranges are similar, it may work. If it is not compatible, perhaps they have another Part # which is.
You program them to your vehicle just like you program a new keyfob remote.
Good luck.
2001 Cougar - 2.5L V-6 - 5 Speed MTX - Black Clearcoat - Medium Graphite Leather
2007 Lincoln MKZ - 3.5L V-6 - 6 Speed ATX - Alloy Clearcoat Metallic - Light Stone Leather with Dark Ebony Wood
BBF2530 is offline
Old 07-06-2008, 01:32 AM   #4 (permalink)
deliveryguy's Avatar
I saw one advertised somewhere that pretty much just installs right over the door handle that doesn't require any wiring...supposedly tunes to the same frequency as your remote entry and performs wirelessly.
WTB
•99-00 Fog Lamps •Aussie Corner Reflectors (01-02) •99-00 Wheel Cap
deliveryguy is offline
Old 07-06-2008, 02:04 AM   #5 (permalink)
Thanks for the info. I didn't even know that there were aftermarket keypads to do this.
Old 07-06-2008, 06:58 AM   #6 (permalink)
Merry Christmas!
LostRacer's Avatar
I believe it is an actual Ford part not aftermarket. There was some info circukating years ago about it because they were cheaply priced at the time. But I'm not sure anyone ever took advantage of it.
The One&Only!
C.A.R.B # FU50
LostRacer is offline
Old 07-06-2008, 07:15 AM   #7 (permalink)
Secretary of the Inferior
B3NN3TT's Avatar
Images: 52
A year or so ago, someone posted a pic of a Cougar in the wild with one of these installed. Goldie's right; it's a dealer-installed item.
Andy- Ohio NECO's "Green Guy"
you make my head hurt.
B3NN3TT is offline
Old 07-06-2008, 11:36 AM   #8 (permalink)
Teebs's Avatar
Years ago (before my time), a guy I work with (i'm an avionics tech) had a calculator pad molded into the dash which required you to push the numbers in a certain order for his van to start. It was a simple circuit and I imagine the same could be applied to the door locks. Maybe not using a calculator pad, since that may look alittle tacky, but using one of the keypads if you can't find a way for it to tie into the stock door locks.
2000 Cougar v6 ATX @ 148, xxx km
Teebs is offline
Old 07-06-2008, 03:10 PM   #9 (permalink)
JRsmoothee's Avatar
I would advise against it because i had friend that had one on his vehicle and it was very easy to get into just randomly push a bunch of numbers and eventually the door would unlock... worked everytime
JRsmoothee is offline
Old 07-06-2008, 09:53 PM   #10 (permalink)
20COUG00's Avatar
Images: 2
Its set up if you hit the wrong numbers, and then after like 5 seconds the alarm goes off.
20COUG00 is offline
