Old 06-27-2008, 07:40 AM   #1 (permalink)
Teebs's Avatar
Slanted box?
I can gains some extra cu/ft for my box if I build it with a slanted back, would this be a problem with a vented box? Would I just have to angle the vents along the backside with the angle of the back?
Thanks
2000 Cougar v6 ATX @ 148, xxx km
Teebs is offline
Old 06-28-2008, 02:21 AM   #2 (permalink)
Puggsley456's Avatar
Re: Slanted box?
If you want to build a slanted box maybe consider using aero ports or PVC. It will make it so much easier.
Puggsley456 is offline
Old 06-28-2008, 02:25 AM   #3 (permalink)
KUGAKRAZY's Avatar
Re: Slanted box?
If you build a box with no slant you can get more cu/ft out of it. As far as venting goes, that all depends on the sound you want, you'd have to look it up in your sub's manuals.
Originally Posted by Nemesis
Great kill buddy! I smoked Type S's all the time in my stock ATX.
KUGAKRAZY is offline
Old 06-29-2008, 02:00 AM   #4 (permalink)
Teebs's Avatar
Re: Slanted box?
How is that? If I put a slant on the back it allows me to use the airspace that would have been between the back of a flat box and the slanted seats. By putting a slant on the back I can gain more cu/ft. And the problem with using the design in the manuals is that it calls for a 44in wide box, where I can only fit a 33 inch box between the brackets coming off the towers in the rear for the seats. Plus I have a strut brace above the box.
Teebs is offline
Old 06-29-2008, 02:25 AM   #5 (permalink)
KUGAKRAZY's Avatar
Re: Slanted box?
Ah, if you were referring to the exact slant of the seat then I agree, a slant is the best way to go. I've had a few hatch style boxes that just made air space because the slant was to big. If you're building your own box then I do recommend building it to fit the car, use all the space you can to get your cu/ft in.
Old 06-29-2008, 01:45 PM   #6 (permalink)
Re: Slanted box?
yes uou can slant it and i wouldnt worry about changing vent positions since the back angle wont be too drastic.
bgred619 is offline
Old 06-29-2008, 09:31 PM   #7 (permalink)
Teebs's Avatar
Re: Slanted box?
Would 2.17cu/ft be to big for a sealed enclosure with 2 subs? Or should I go ported? The reccomended enclosure by the manufacturer is .75cu/ft. per sub. It doesn't say if that's with or without the sub inside. And vented is 1.25cu/ft per sub.
I was thinking of doing a vented enlosure, but now I'm wondering if I should go with a sealed enclosure. I know I won't hit a high spl with the sealed, but I'm thinking it would go nicely with the carputer, 4 channel amp, alpine type r components and 2 ways... The two subs together are being pushed with 900watts RMS, 450Watts RMS to each. Which is 50RMS over their rating, but that shouldn't be a problem...
Teebs is offline
Old 06-29-2008, 10:01 PM   #8 (permalink)
michcougar's Avatar
Re: Slanted box?
Ive never heard of measuring cu/ft with the sub inside. Its always just the size of the box.
So according to your .75 I would say ya 2.17 is too big for 2 subs.
Msds-Injen/GMK-magnaflow-svt-Xcal2-b&g-kyb-tezzen-clarion-earthquake
michcougar is offline
Old 06-29-2008, 10:10 PM   #9 (permalink)
Re: Slanted box?
actually i always count the sub as taking up space. as for spl ive always had higher #'s with sealed enclosures, then again didnt play with ported box for to long. also went through 4 different box sizes till i got to the sound that i liked.
dont know which subs your installing so dont know what power it would handle.
bgred619 is offline
Old 06-29-2008, 10:27 PM   #10 (permalink)
Teebs's Avatar
Re: Slanted box?
The subs are 2 10" MTX MXS1004s. Rated for 800watts max and 400rms. And + or - 50RMS won't kill them.
The original intentions were to build a box that would fit where i wanted it and then vent it accordingly to get the sound I was looking for... Now i'm undecided?!
Teebs is offline
