Old 06-06-2008, 05:23 PM   #1 (permalink)
XRTONY's Avatar
Internal amp
Is there an internal amp on the stock system? If so where is it located. Thanks!
XRTONY is offline
Old 06-06-2008, 05:32 PM   #2 (permalink)
JRsmoothee's Avatar
Re: Internal amp
yeah its in the dash where u put those shiny disc shaped objects that play music hahaha
JRsmoothee is offline
Old 06-06-2008, 05:36 PM   #3 (permalink)
XRTONY's Avatar
Re: Internal amp
Just checking, best buy has a cool little wire that contains the 4 speaker wires and a remote wire that you just connect behind your dash and run it back to your amp so you don't have to pull new wires. Just making sure i didn't run into any problems with an external amp hiding somewhere like on my premium sound system for my old ZX2.
XRTONY is offline
Old 06-06-2008, 05:40 PM   #4 (permalink)
JRsmoothee's Avatar
Re: Internal amp
really you got a link to what you are talking about i was thinking about adding a sub to my factory deck but didnt want to have to splice into anything ......if that is what your talking about
Old 06-06-2008, 06:10 PM   #5 (permalink)
XRTONY's Avatar
Re: Internal amp
When I had my bass tube installed they just tapped into the rear speaker wire for the signal. Then all you have to do it run power, ground and remote. You might be even able to remote of the speaker wire. I don't see why not.
XRTONY is offline
Old 06-12-2008, 06:06 PM   #6 (permalink)
Audiobahn Abuser
blustreak's Avatar
Re: Internal amp
You are referring to a "line-out converter". You can hook it up to your rear speaker wires and then hook up a set of RCA's for your subs to the loc. Some seem to have better sound quality than others but none are as good as running a new HU and full length RCA's IMO.
WTB: Vortech Spec MSDS Headers : Front Adjustable Koni's : Good condition Stock MTX Shift knobs : 3 gauge Pillar pod : 4 gauge Airbag pod
FS: New WeaponR Headers & Y : COP set : Walbro 255lph fuel pump : Cougar S CF Hood : 2 Pillar gauge pod - LSB : Razzi High Rise Spoiler - Silver : 19" Icon W64's w/ Toyo Proxie4's : Misc 3L Parts : +more just ask if I have it
cougardb
Like to travel?
blustreak is offline
Old 06-12-2008, 07:26 PM   #7 (permalink)
JRsmoothee's Avatar
Re: Internal amp
yeah i've seen those, i just thought he found something that just plugged into the back of his factory deck that that gave him instant preouts, but i guess im just gonna have to waste some money on a new HU so i can get a lil bit of bass
Old 06-13-2008, 08:51 AM   #8 (permalink)
Capital Curmudgeon
skater's Avatar
Re: Internal amp
Some stock radios do have this; for example many GM radios made over the last five years or so can do this, using an adapter that plugs into the harness behind the radio. I don't think any of the stock radios in the Cougars had that ability, though.
skater is offline
Old 06-16-2008, 11:01 AM   #9 (permalink)
CSVT_2004's Avatar
Re: Internal amp
That would be speed wire, The Install Bay
That is used for doing 4 channel amp installs or extending wires to do a factory amp bypass...
Your not going to get away with that unless you have an aftermarket deck or a factory kenwood unit like some tiburon's have. I have yet to see any other car have factory RCA outputs...
As far as I'm aware there are not direct harnesses that do this, they only way that I can think of to getting around not having to splice the factory wires would be to but an adapter harness for installing and aftermarket radio and then also buying the reverse harness to go back to factory wiring them together and adding your LOC in between them that would allow you to not have to modify the factory wiring...
1999 CSVT #1745 of 2760 T-Green/P-Tan DD Viper 791XV & Res Del
1999 CSVT #1831 of 2760 T-Green/P-Tan Project Car
Geek Squad Autotech [MECP Cert]
CSVT_2004 is offline
