Old 05-28-2008, 11:38 AM   #11 (permalink)
Re: Added factory cruise control
I dont have the delete cap. badasscougar has one on his car, might be able to hit him up... but once again, its just shorting 2 pins.
ya kinda takes you by suprise when you go for your horn and get nothing.... I gave up trying to get this delete cap [couldnt even get a part number for it] and just removed the horns.
Old 05-28-2008, 02:21 PM   #12 (permalink)
Redlineracer12's Avatar
I never tried honking the horn while I didn't have the module or cap hooked up. You guys are crazy, I used my cruise control ALLLLL the time in my probe, then I bought the Cougar and have been missing it ever since! Otherwise I tend to vary speeds from around 10 under to 15 over when I'm not paying close attention
99 Coug V6 MTX Spruce Green
SVT "Heavy" swap finshed!
CSVT #1321/2150 Born on 1/6/00
213.5whp
Redlineracer12 is offline
Old 05-28-2008, 05:58 PM   #13 (permalink)
I dont use it because I can get high mpg without it
.... that and with it, I have a tendancy to stop paying attention to the road.
Old 05-29-2008, 02:29 AM   #14 (permalink)
You Got Rondo'd!
aircougar1's Avatar
Images: 1
I'm too tall, and end up hitting the pedals with my feet anyway!
might as well keep the feets on the pedals since there is no room for them anywhere else!!!
So, what part of the cruise system causes you to lose the Horn's functionality? I would think that just removing the cruise servo, cable, and the steering wheel would allow you to retain horn function...???
"YAHTZEE!!!!"
1999 Laser Red Cougar Mtx
aircougar1 is offline
Old 06-07-2008, 03:18 PM   #15 (permalink)
You Got Rondo'd!
aircougar1's Avatar
Images: 1
Where is the connector that needs to be shorted located? I am guessing the connector for the servo control box?
I just tried that location on newcat016's Cougar and it didn't work...
"YAHTZEE!!!!"
Old 06-16-2008, 01:46 AM   #16 (permalink)
You Got Rondo'd!
aircougar1's Avatar
Images: 1
I found the connector on JScullin's Cougar, and found out that PINs 6 and 10 are jumped... using a factory delete cap....
Just thought I would place that info here for anyone that was wondering.
"YAHTZEE!!!!"
Old 09-15-2008, 09:16 AM   #17 (permalink)
Is it possible to connect the cruise control buttons onto a non-cruise wheel?
Chessmaster is offline
Old 09-15-2008, 12:51 PM   #18 (permalink)
Was that sposed 2 happen?
ModCougar's Avatar
I need one of those clutch pedal switches with the four prongs... I have everything else hooked up on my coug (mine also didnt come with cruise control, but I have everything installed except that one switch).
- WTB: front struts, springs/coilovers, 19mm rear sway bar, inner/outer tie rod ends - headers, and black or gunmetal gray wheels - Roush floormats, wheels, pedals, and spoiler
- For Sale: '99 Headlights - Kaminari Wing - Stock Throttle Body - IACV - Misc. stock engine parts
- 1999 Mercury Cougar V6 MTX - Kaminari/Roush/SVT
ModCougar is offline
Old 09-15-2008, 11:56 PM   #19 (permalink)
Banned
hmm.. stock cruise control had buttons on steering wheel I guess? I had a little switch that was on the side of the steering column area.. I cut out the cruise control module and never had a problem with my horn..? I guess it was aftermarket?
c0alition is offline
