| Notices |
#1 (permalink) | |
The race to Fest!
Looking to install 2 amplifiers before Fest. One 800W RMS mono, and a 400W RMS 4 Channel. So far I have the battery relocation kit from Steeda, which I plan on using for a dual battery, rather than a relocation. This will be hooked to a carpc, with a 5.1 sound card. So the 4 channel amp, will have 4 independant channels. And the sub will have it's own output.
This is what I received from Steeda. What else do I need? Quoted from the GB thread: Quote:
2000 Cougar v6 ATX 1GHz Carputer - Alpine Components - Kenwood Amps - Jaged RSTB - Jrak Toe Arms |
5% Nation of
Re: The race to Fest!
ya I dunno, good question, I also picked up that kit from the GB. Its still sitting in my attic but the time is coming that I really need to get it installed.
1994 Lincoln Towncar w/ 112576 1996 Contour SE MTX loaded w/ 134592 1999 Silver Frost ATX original owner w/ 70049 [in storage] "why buy it when you can build it for twice the price??!?!" Contour by day, Cougar by night. |
She purrs ;)
since you have 2 batteries, you might want to consider an isolator setup.
Rolling Chassis
![]() Join Date: Nov 2002
If you use two identical batteries then an isolator is not required, but I generally recommend one. However, with a 0/1 setup you're going to have a hard time finding an isolator that can allow the amperage draw-through. I used to run an MBR-70 from Orion, but even that only let 70amps through and cost upwards of $500 brand new.
If you run dual Optima's (or another high-quality SEALED battery) you can simply wire them up direct. E1
Would I actually gain any benefit from dual battery with the power i'd be drawing? Or should I just toss the stock battery and throw in an optima or something?
#6 (permalink) | |
She purrs ;)
Like E1 said, you would have to have an exactly same brand batteries to have it hooked up without an isolator. In fact, they recommend that they are exact same age. when you have an isolator, batteries dont have to be a same brand.
Capital Curmudgeon
I thought the point of the isolator was to keep one battery able to start your car while you use the other battery to run your system with the engine off? It has nothing to do with the types of batteries installed...
At least, that's how the isolator in my camper works... (though you can substitute "the 12 volt appliances and lights" for "system")
#8 (permalink) | |
_
The One&Only! C.A.R.B # FU50 |
#9 (permalink) | |
She purrs ;)
![]() i said the batteries have to be identical if he wants to run it without an isolator and hooked up together.
#10 (permalink) | |
Rolling Chassis
Momo is correct. If you use different batteries w/o an isolator you risk having a discharge or feedback, thus killing the entire car + system. Isolators work two-fold, first they allow you to drain the system battery w/o killing the starting system for the car, and second they allow you to isolate any stereo issues from the main power system of the car.
E1
