Old 05-13-2008, 05:50 PM   #11 (permalink)
Capital Curmudgeon
skater's Avatar
Re: The race to Fest!
Originally Posted by MOMO View Post
you are absolutely right but you forgot to read my post.
i said the batteries have to be identical if he wants to run it without an isolator and hooked up together.
I read the ****ing post. I'm asking a question about it.
Originally Posted by EternalOne View Post
Momo is correct. If you use different batteries w/o an isolator you risk having a discharge or feedback, thus killing the entire car + system. Isolators work two-fold, first they allow you to drain the system battery w/o killing the starting system for the car, and second they allow you to isolate any stereo issues from the main power system of the car.
I think I see what you're saying - power can flow from the engine electrical system to the secondary electrical system, but not from the secondary to the primary (essentially there is a diode in there)? That's cool - I didn't know they did that. I've never tested that on my camper, but it does match what I've heard: Someone with a camper like mine said they jumped their engine off the deep cycle battery using jumper cables (which is funny on a couple levels), and presumably the cables wouldn't have been necessary if the isolator allowed power to flow back in the other direction.
skater is online now
Old 05-13-2008, 10:23 PM   #12 (permalink)
Teebs's Avatar
The mono amp has 2 30A fuses, the 4ch has a 40A fuse. So I could benefit from dual battery, but from a cost vs benefit point of view it may not be the greatest investment?
Isn't the alt 130amp? And 70amp at idle? Or am I mistaken?
2000 Cougar v6 ATX
Teebs is offline
Old 05-14-2008, 04:00 PM   #13 (permalink)
Won't settle 4 quick fix
LinkMan's Avatar
Images: 11
When I was diagnosing a charging issue on my Cougar, I used a clamp-on ammeter, and at idle with headlights + foglights on, cabin fan on high, A/C on (which also turns the engine cooling fans on), as well as the stereo/sub playing, it was pulling around 75 Amps, give or take.
So you're not mistaken.
Mark (AIM:LaserRedCat)
1998 T.Red Contour V6 ATX FCO
1993 Bright Red Tempo 2.3 ATX
LinkMan is offline
Old 05-14-2008, 04:26 PM   #14 (permalink)
She purrs ;)
MOMO's Avatar
somebody is hostile today.
MOMO is offline
Old 05-14-2008, 06:47 PM   #15 (permalink)
Capital Curmudgeon
skater's Avatar
Old 05-15-2008, 09:15 AM   #16 (permalink)
Rolling Chassis
EternalOne's Avatar
Right, so at max pull your stereo can pull down 100 amps, while the car only produces between 70-130amps (lower if the alt is slowly dying).
Right, except the car pulls 75amps, and his stereo can pull a max of 100amps -- over what the Cougar can produce. Since it's "close" a dual battery would be the best bet here, as the times when it's pulling more the batteries can compensate, while times with low draw can recharge the system.
E1
EternalOne is offline
Old 05-15-2008, 01:55 PM   #17 (permalink)
She purrs ;)
MOMO's Avatar
MOMO is offline
Old 05-15-2008, 02:20 PM   #18 (permalink)
Pedestrian :(
LostRacer's Avatar
settle down kids
The One&Only!
C.A.R.B # FU50
Originally Posted by Yofavcracka
hahah for a second i didnt realize you meant to type "accent" and i thought you typed "scent"
I was like.. wtf? you're getting scented carbon fiber?
West Coast Prowl Hotel Proposals!
LostRacer is offline
Old 05-15-2008, 03:14 PM   #19 (permalink)
LinkMan's Avatar
Images: 11
E1
I was only commenting on his "at idle" question. That's why I didn't quote the part of the question concerning the dual battery.
LinkMan is offline
Old 05-15-2008, 03:39 PM   #20 (permalink)
kwg2371's Avatar
I'm gonna jump in here for a second, I'm running 2 mono block amps for my L7's and I keep fryin my ALT both amps have 3 25amp fuses= 150 amps total I have a powercap that is rated 24 volt surge protection and is 2 farad the anl fuse is 300amp so in other words ineed to tinker with the ALT to make it store/ make more power?
What if i was to put another battery in the is the same as what I have+ have the powercap on?? would that solve any thing with out messing with the ALT
http://www.myspace.com/kwg2371
If your cougars not broke, you are.
If your going to sell somthing POST your price and location
kwg2371 is offline
