Old 03-13-2008, 09:05 PM   #1 (permalink)
Obey
Platinum MemberAdministrator
JScullin's Avatar
Question 1999-2002 Bulb Identification
Quick list for easy access. Some of the bulbs can be replaced with LED versions for a brighter, longer lasting, light. If you want to stick with standard bulbs some come in a "LL" version which uses a longer lasting filament.
Low beam headlamp
9006
High beam headlamp
9005
Parking light
3157NALL
Front turn signal
3157NALL
1157NA 2001+ models
Rear turn signal
3157
Tail light
1156
Stop light
1157
High mount stop light (trunk brake light)
2825
Fog/Driving light
H3-55W
9145 2001+ models
License plate
2825
Back up light
1156
Front sidemarkers
194
Dome light
3886X
Trunk/Cargo area
6411
Gauge Clusters 99-02
Each cluster has (3) #194 Bulbs
All the indicator/dummy lights are #74 except for the Airbag light and the Check Engine light which are LED's
JScullin is offline
