Old 03-05-2008, 08:41 AM   #1 (permalink)
Help - 99 Cougar Gages
When I turn on the key, the MPH and RPM gages go crazy and jump from minimum to max, then everything is ok. I would just ignor this but the clock changes times every time this happens. Any suggestions? Thanks.
fairmont is offline
Old 03-14-2008, 05:26 PM   #2 (permalink)
burton160w's Avatar
Re: Help - 99 Cougar Gages
my guess is a grounding issue. Check all the wires related to your ignition. Also, check your terminal connections to a battery. when you start the car and the terminal connection is loose - it can jump around, causing a quick stall, course the connection gets made starting your car, but since you technically "unplugged" from the battery, the clock resets.
Originally Posted by bdiddy
absolutely. the market goes up and down. that's what it always does. just let it happen. it's natural. just like crack babies. just because it doesn't seem right, doesn't mean Desolator's mom shoulda had an abortion
burton160w is offline
Old 03-14-2008, 08:18 PM   #3 (permalink)
Got Rice?!???!!??
Drewmanfu0's Avatar
Images: 49
A fuse under the dash probably blew check all of them.
Drewmanfu0 is offline
Old 03-14-2008, 11:41 PM   #4 (permalink)
freednighthawk's Avatar
I just had a very similar issue, every time I would start the car the guages would reset to 0, the overheads were out, and the mirrors wouldn't work. Took it to Ford and they said it was wiring behind the dash, same with the dealership we bought it from...
Long story short, check fuze #34 under the dash. Should be a 7.5.
Bone stock 99 Rio Red ATX Cougar... Bet you havent seen one of these before :P
Mostly Stock Charcoal Metalic 89 S10 Blazer
freednighthawk is offline
