#83 (permalink) | ||
Re: Post your audio system!
I never had a problem with mine in the 2 or 3 years I had it...
![]() (pics in post #2 if they still load... server is fussy sometimes)
~Matt~ ND4SPD Army Kommandant ![]() Amanda and I has a penguin... somewhere. ![]() Quote:
#84 (permalink) |
my x400.1 hardly even gets warm when im running at 4 ohms:D
#85 (permalink) |
Sunshine owns me
After just an hour? I'm not just saying when it's 90 degrees..it can be 70 and still overheat.
"PROUD MEMBER OF THE ND4SPD ARMY" Titans 11-1 ![]() Matt and I are proud parents of a penguin named Randy. That picture is really him! So precious!I would rather be shocked by the truth than disrespected with a lie. Being angry at the truth is momentary. The sadness that dishonesty provokes takes much longer to recover from. |
#87 (permalink) |
If your amps are getting absolutely no airflow, which I assume they aren't being enclosed under plexi-glass, an hour seems reasonable. The thing that is worrisome is that if you keep overheating the amps, they WILL fail at some point. It'd be best to improve airflow sooner than later.
"You're captives of a civilizational system that more or less compels you to go on destroying the world in order to live." - Ishmael 2001 Cougar 2.5L MTX My old '99 MTX cougar |
#88 (permalink) |
Sunshine owns me
If I'm on a trip that's longer than an hour, I will turn them off before I even leave.
And that's right, no air flow at all. I have this plexiglass that has holes in it, but I don't think that would look right.
#89 (permalink) | |
#90 (permalink) |
Rolling Chassis
![]() Join Date: Nov 2002
Buy some slimline directional airflow fans. Computer fans won't move enough air to cool the amps properly. You need to move a flat line of air across the entire heatsink of the amp for any cooling to be effective. Most likely the amp is not overheating, it's going into protection mode and shutting itself down before it does overheat. If it overheated multiple times, you wouldn't have amps left.
![]() My amps all run SUPER hot -- like if you touch them they WILL brand the Orion logo on you. Of course I'm running 2400 watts out of each of them at 1ohm. =) E1
