Closed Thread
Old 01-10-2006, 11:32 PM   #1 (permalink)
CougarGT's Avatar
Lightbulb 3.0L Swap Parts List
PM Me your parts list and I will update the thread.
DemonSVT/Ford Rule's List: - Thanks for Sharing!!!
FEL-PRO gaskets AUTOZONE
ES72159 3LHead bolt set (2 sets req)(22.99 each) 45.98
9540PT 3L left hand head gasket 41.99
9541PT 3L right hand head gasket 41.99
VS50462 2.5L Valve cover gasket set 42.99
TCS45966 3L Camshaft Rear Seal Gasket Set 12.99
TCS45967 3L Crankshaft Front Seal 19.99
SS72873-1 3L Valve Stem Seals (Viton) 38.99
MS95726 2.5L Intake Manifold Gasket Set 39.99
MS95715 Exhaust Manifold Gasket (53mm x 32mm) 9.99
5L8Z6675AA $154.50 $0.00 $111.24
Engine - Lubrication - Oil pan
OIL PAN, Escape, Mariner, From 7/18/03 - 3.0L 2003 - 2005
Fel-Pro Part# CS9038 2.5L Conversion Kit (includes oil pan gasket, oil seals etc)
Fel-Pro Part# HS9038PT 2.5L Head Gasket Set
Fel-Pro Part# 9038PT 2.5L Left Hand Head Gasket
Fel-Pro Part# 9039PT 2.5L Right Hand Head Gasket
Fel-Pro Part# 9540PT 3L Left Hand Head Gasket
Fel-Pro Part# 9541PT 3L Right Hand Head Gasket
Fel-Pro Part# ES72159 Head Bolt Set (2 req.)
Fel-Pro Part# MS92586 3L Plastic Oval Port Intake Manifold Set
Fel-Pro Part# MS95715 Exhaust Manifold Gasket (53mm x 32mm)
Fel-Pro Part# MS95726 2.5L Intake Manifold Gasket Set
Fel-Pro Part# SS72873-1 Valve Stem Seals (Viton)
Fel-Pro Part# VS50462 Valve Cover Set
Fel-Pro Part# TCS45966 Camshaft Rear Seal Gasket Set
Fel-Pro Part# TCS45967 Crankshaft Front Seal
Fel-Pro Part# OS30675R Oil Pan Set
Fel-Pro Part# 61006 SVT TB Gasket
F7RZ-9E926-AA SVT Throttle Body
F8RZ-9677-AA SVT TB Bracket
XS8Z-9A758-CA SVT Throttle Cable
F5DZ-9E936-AE SVT TB Gasket
F5RZ-2A411-A 2.5L UIM Plastic Retainer Grommet with Brass Insert Sleeve
F5RZ-2L181-AA 2.5L UIM Plastic Retainer Grommet
2S7Z-9J559-AA Intake Manifold Runner Control (IMRC)
F5RZ-9F955-AB Intake Manifold Runner Control Linkage Grommets (3 req)
2.5L Crankshaft Timing Scrocket
Ford Part #: F8RZ-6306-AA
Vendor: Signature LM
Cost: $24.28
Quantity: 1
Total Cost: $24.28
2.5L Timing Chain
Ford Part #: F6DZ-6268-CA
Cost: $47.96
Quantity: 2
Total Cost: $95.92
2.5L Timing Chain Guide (right)
Ford Part #: F8RZ-6K297-BA
Cost: $14.24
Quantity: 1
Total Cost: $14.24
2.5L Timing Chain Guide (left)
Ford Part #: F8RZ-6K297-AA
Cost: $22.50
Quantity: 1
Total Cost: $22.50
2.5L Timing Chain Tensioner Arm
Ford Part #: F6RZ-6L253-BA
Cost: $24.73
Quantity: 2
Total Cost: $49.46
Ford Part #: F6RZ-6L266-BA
Cost: $36.80
Quantity: 2
Total Cost: $73.60
2006 Black Ford Ranger FX4
CougarGT is offline
Closed Thread
