Mazda 3.0L w/ Variable Valve Timing????
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Mazda 3.0L w/ Variable Valve Timing????
    EatRice
    Guest
    I am not sure if this has been brought up or not, I have not seen it though, so just thought I'd ask. Does anyone know if this would be easily feasible? The new 3.0L in the Mazda 6 is a duratec engine with variable valve timing, it is even made in the same Cleveland Ford plant as the duratec in our cars. This engine puts out 220hp and 192ft-lbs to the crank, and is a much higher revving engine. Any ideas as in if this would be as easy as a swap from the Taurus/Sable, or as cheap for that matter? Any inputs would be appreciated. Thanks.
    be trollin fer trolls Lifetime Platinum MemberAdministrator FastCougar's Avatar
    1999 Nov
    Eastern Panhandle, WV
    8,297
    Cheap ... NOT (Newer car replacement engines are ALWAYS more expensive than older cars)
    Swappable ... probable
    Cleveland Plant ... NOT (AutoAlliance in Flat Rock, MI)
    Higher Reving ... NOT (lower redline, 6500 RPM vs. 6750 RPM)
    Former owner of a 1999 Mercury Cougar - Turbo'd 3L "Mavro Gato".
    For Sale: Turbo Cut Heads (w/SVT cams), All New Timing Equipment - PRICES SLASHED!
    EatRice
    Guest
    Well, actually, the car's final assembly IS in Flat Rock, MI. However, both 2.5L Duratec and 3.0L Duratec engines are assembled in the Ford's Cleveland Engine Plant 2 on Snow Rd. boardering Brook Park, OH and Cleveland, OH. They also assemble the same 3.0L that are in the Jaguar X-type and now in the Mazda6. Here is a link to an award of excellence they won for the Duratec engine:
    http://www.shingoprize.org/web/busin...re97/cep2.html
    The redline is not as high, however the Mazda6 keeps peak horsepower from 6300rpm to the 6500rpm redline, unlike our cars where we hit peak hp at 6250 then power drops off considerably by 6300rpm. Hence, the 3.0L in the Mazda6 supplies more power at a higher RPM.
    Now, I was just wondering if anyone knew if it would be as easy to install as the 3.0L from the Tauras/Sable.
  5. Remove Advertisements
  6. #4
    NECO Member pgtatx's Avatar
    2001 May
    4,189
    The Jag xtype engine and the Mazda 6 engine are not the same thing.
    The blocks are all cosworth cast block, however th heads and electronics are different. The New 3L heads in the Mazda 6 are different and use their Sequential Valve Timing (SVT - not special vehicle team) system, compared to the Jag x type which uses variable valve timing.
    I'd assume the block can be used, but the rest probably not. However anything is possible.
    No the swap isn't as easy as the taurus as electronics have changed much and will continue to change. You'd probably need a lot of new wiring. Not worth it...
    Just use the 3L from a taurus and a better top end (p&p heads, etc) and you'll make 220hp easily.
    -Sold: '99 Cougar V6 MTX
    -Sold: '04 Subaru Impreza WRX STi... Lot's of mods
    -Sold: 2005.5 Audi S4 6MT... Stock
    -2005 Dodge Ram SRT-10 RC B&B Headers, Mids, Rear, K&N, SCT Tune
  7. #5
    Moderator Moderator slockin's Avatar
    2000 Oct
    Troy, NY Sucks!
    796
    At least the Mazda 6 is offered in a MTX - meaning that we'd actually have a 3.0 MTX computer program. Could of been another reason why the mythical Cougar S never got the 3.0 - there was no existing 3.0 MTX software.
    -Nick
    2K2 Dark Shadow Grey V6 MTX
    Empire NECO VP
  8. #6
    1999 Nov
    8,297
    What software is involved with a manual transmission?
    Sorry about the AutoAlliance/Cleveland mixup ... I misread what you wrote.
  9. #7
    T3/T4 60-1 PuckPuck's Avatar
    2000 Oct
    Windsor, Ontario, Canada, 108634965827573, Windsor, Ontario
    8,015
    The big deal with the 3.0L vs. 2.5L is the timing cover. Yeah it's just a cover, but besides displacement it is the #1 difference between the 2 engines. On the 3.0L the timing cover is 3-4" longer, meaning physically it won't fit. That's why you need to run the 2.5L timing cover.
    VVT would have it's gears contained in the timing cover. So basically you would have to run the 3.0L timing cover to get VVT.
    In other words... unless you redo the entire engine bay, even with the wiring harness and the PCM from the mazda6 or x-type you will not be able to use VVT because you have to run the 2.5L timing cover which has no provisions for VVT gears on the camshaft.
    So will the block work - YES... will you ever get VVT to work without fabrication of the engine bay - NO... with that knowledge, just buy a cheaper block and use your existing heads or the 3.0L "normal" heads.
    PuckPuck.Com
  10. #8
    1999 Nov
    8,297
    Don't forget Coil-on-plug, which the 6 uses as well as some 3.0L Sable/Taurus.
  11. #9
    2000 Oct
    8,015
    you should always run the coil pack that came with the PCM... i'm sure you can make the mazda6 work on the same coil pack that our 2.5L uses but you'll need a computer to control it
    PuckPuck.Com
  12. #10
    1999 Nov
    8,297
    Yep ... that is what I was getting at ... it would require the 6 ECU, no questions. However, will the ECU fit in the stock location? Is the engine harness/ECU adapter the same? If not, more fabrication would be required. Let's not forget the number 1 factor ... cost. You probably couldn't touch one for under $2K
  1. Variable Cam Timing Sensor
    By scott.young in forum Problems
    Last Post: 2009-10-31, 12:42 PM
  2. FS: Garage sale! -- Eibachs, shortram, valve/timing covers, wiring, and more!
    By wadespencer99 in forum FS: Automotive Parts & Accessories
    Last Post: 2008-07-24, 09:58 PM
  3. 3.0 swap...variable valve timing....
    By Dom1013 in forum 3.0L DURATEC Performance
    Last Post: 2006-05-11, 01:04 PM
  4. No variable valve timing
    By Schlapster in forum Problems
    Last Post: 2004-04-09, 09:23 PM
  5. Variable Valve Timing?
    By Dekz in forum 2.5L DURATEC Performance
    Last Post: 2003-03-07, 08:38 AM
