Old 01-03-2006, 09:52 AM   #31 (permalink)
Gebby's Avatar
Re: READ THIS FIRST - WHAT ENGINES WILL FIT MY CAR?
i did not see this anywhere but what about a 3l out of a 96 sable? i was wandering because i have one in my other car. if it will not work then when i get ready to do the swap i will find another engine.
Gebby is offline
Old 01-03-2006, 10:18 AM   #32 (permalink)
Banned
jrak123's Avatar
no
jrak123 is offline
Old 01-07-2006, 01:23 PM   #33 (permalink)
travelbill's Avatar
The Lincoln LS/Jaguar 3.0 engines from 2002-2002 did not have VVT, this was introduced in the 2003 MY. The '00-'02 engine made 215 HP at the crank and 178 at the rear and should be compatable. The intake manifolds are quite different from the FWD engines, this is where a lot of the modification would have to take place.
travelbill is offline
Old 01-07-2006, 08:54 PM   #34 (permalink)
I have a secret. :)
BigBalledOX's Avatar
Images: 51
And . . . *drumroll please* . . . MAJOR fuel line modifications due to FWD vs RWD/AWD.
Not trying to start a flame war here, but can we see some credentials? There are many VERY knowledgeable people who have assembled this FAQ through experience, so I kinda wonder who you are.
There is in this world no greater force than that of a man determined to rise.
SONZA IS CANADIAN.
its a money pit!
BigBalledOX is offline
Old 01-09-2006, 11:16 AM   #35 (permalink)
Completely incorrect. All Jaguar X-type engines 2.5L or 3.0L have VVT on them. The LS is a different car and the engine is mounted differently so it is quite possible the LS didn't have VVT until later on. There is no question that the Jaguar X-type has had it since it was put on the market in 2002. The LS does have a lower hp rating for 2002 at 210hp vs the Jag's 231hp so it's possible that the LS didn't have VVT until 2003.
Old 01-09-2006, 11:33 PM   #36 (permalink)
StealthyWeasel's Avatar
For which years do the SVT Cams switch in with no extra work?
10,100 RPM
Once it's done, it's done! Can't wait.
StealthyWeasel is offline
Old 01-11-2006, 10:13 AM   #37 (permalink)
01+ Tarus/Sable/Escape engines
Old 01-29-2006, 12:01 PM   #38 (permalink)
travelbill's Avatar
No problem, I've been northeast region director of the Lincoln LS Owner's Club for several years, I own an '00 Lincoln LS with 3.0L and one of the rare Getrag manual transmissions. Also for MY '03 and forward the throttle was changed from mechanical to electronic. I've been roving boards for lots of different cars to try and find what people are doing to modify their 3.0's. The best example I've found is the Roush tuned 3.0 for the Noble, that sucker puts out 425 hp with modified cams, port & polished heads, forged pistons and twin turbo's, but at $18,000 an engine I guess you should expect as much.
I'm not positive, but I believe the biggest difference in the LS/Jag engine is in the heads, the valves and cams use DAMB tappets instead of the rollers used in the taurus/sable. In the Jag it's known as the AJ30 engine. Believe it or not the 3.0 was orriginally a Porsche design which they sold to Cosworth(which Ford just sold) who developed the 2.5 Duratec and eventually bored it out to the 3.0 litre size.
2000 Lincoln LS 3.0 MTX looking for ways to mod my engine.
Old 03-29-2006, 05:59 PM   #39 (permalink)
99ADCCOUGAR's Avatar
how difficult would it be to get a 3L swap into my 99 mtx coug??? and the infamous question...HOW MUCH
Dave decided he wants to move out on his own.
1999 White Cougar MTX 2.5 - Built as much as I could with what money i had. 226 fwhp on the funny stuff SOLD =( minus the motor
1998 MB E320 - ROAD MONSTER, SLK32 AMG Supercharger Unit, Renntech Pulley,ECU,TCU upgrades, Lowered, 18x9 on all 4 corners = 450bhp/ 475tq/5 spd auto/Handles like a beast = Kick Major Culo on Highways..... Fun stuff now for my Uncle SOLD =(
99ADCCOUGAR is offline
Old 03-29-2006, 08:06 PM   #40 (permalink)
When I asked the 3L Install Maestro I was told around 3g, not sure if that counted the engine though ...
Edit: BTW does anyone know anything about the 3L crate engine on arizonadynochip.com ?
AnthonyP is offline
