Old 11-06-2005, 10:21 PM   #21 (permalink)
Cossack's Avatar
Re: FAQ - MOST OF YOUR 3L QUESTIONS ANSWERED
ok what parts do i need for a hybrid, and would it be ok to use this with my ATX witha tranny cooler.
Cossack is offline
Old 11-26-2005, 12:29 PM   #22 (permalink)
I am doing a full 3.0 swap into my CSVT. What do I need to do with the IMRC? I have read you leave it hooked up to a spring (not what I want) and also that you can just leave it off and not wired and not get a CEL. What have you guys done?
I am also looking to extract the ATX bushing from the crank rather than cut it off. I have packed the hole with grease, but I need a better weapon to attack it with than my 17mm socket and extension. Any ideas other than cut it off or is that the most common solution?
Green1999CSVT is offline
Old 11-26-2005, 05:41 PM   #23 (permalink)
Only way around the IMRC trick is to get a chip burnt from ADC that will eliminate the IMRC and give you the timing you need down low.
As far as the bushing. I've aways cut it off. I'm not sure what a socket and extension have to do with the bushing though. Your suppose to get a dowel and tap it in. That pushes the bushing out.
Old 11-26-2005, 06:19 PM   #24 (permalink)
I was substituting the socket for the dowel...will a wood dowel work? I was trying to avoid grinding, seems rather crude.
What have you typically done with the IMRC on your swaps? Don't the ADC chips cost close to $500? Iwon't have much more than that in the whole swap, maybe best bet is to leave the IMRC hooked up, but just cut off the cable?
Old 12-12-2005, 02:36 PM   #25 (permalink)
weargle's Avatar
Engine tech
Timing cover tech
Head gasket tech
-- Wes
1995 Mazda Miata (ES --> CSP over the winter)
2000 Ford Contour SVT (jealous of the Miata so she broke an engine to neener neener me)
Free Ford Factory Service Manuals for download: http://www.fordcds.com/
weargle is offline
Old 05-18-2006, 10:06 PM   #26 (permalink)
so would a 2001 atx escape engine have a problem fitting in a 99 atx cougar
and what would i need to change when im putting the engine in?
gameover0015 is offline
Old 12-28-2006, 09:39 PM   #27 (permalink)
I read all the post in here just asking for you opinion (those with the 3L). Whats the better engine to put in, the 01+ engines or the earlier model?! and the car as well, Taurus/Sable/Escape Thanks
Will
99cougarsupreme is offline
Old 12-29-2006, 05:12 PM   #28 (permalink)
azbobbybooshay10's Avatar
Images: 6
Originally Posted by gamiller
this doesn't appear to address the difficulty of going from a return fuel system to returnless. i know not everybody will face that issue, but it is noteworthy...
I just realized this will be an issue with me. My Cougar is return-style, and the 3L's are returnless, right? I was planning on doing the full 3L, using 3L manifolds and all. How will the fuel system affect this?
2008 V8 Supercar Championship Standings (After Round 9 of 14, L&H 500 Enduro @ Philip Island)
1. #1 - Garth Tander - Toll Holden Racing Team Commodore..................2096
2. #5 - Mark Winterbottom - Ford Performance Racing Falcon................2043
3. #88 - Jamie Whincup - Team Vodafone Ford Falcon..........................2016
NEXT RACE: The Great Race, the Supercheap Auto Bathurst 1000 @ Mount Panorama, October 12, 2008
azbobbybooshay10 is offline
Old 12-29-2006, 06:33 PM   #29 (permalink)
BigBalledOX's Avatar
Images: 51
Custom fuel rail FTW.
MEMBER OF THE NECO LIB CREW!
its a money pit!
BigBalledOX is offline
Old 01-03-2007, 11:04 AM   #30 (permalink)
You'll need to build a custom fuel rail. It sucks to build but it can be done.
