3.0 swap
Results 1 to 3 of 3
Thread: 3.0 swap
    2012 Apr
    Orlando,Fl
    390
    Exclamation 3.0 swap
    I was wondering what all it would take to do a full 3.0 swap?
    What transmission can i use?
    What 3.0 duratec can i use? ( read on wiki theres like a few different kind of duratec 30's)
    Do i need a new exhaust setup up?
    NECO Member aboythatskates's Avatar
    2010 Mar
    spokane washington
    2,982
    Re: 3.0 swap
    read the stickies on top of the 3L section. it will answer EVERYTHING!
    if you need a link let me know
    also, you can read other peoples build thread to learn more
    Full 3L '99 Mercury Cougar MTX.
    195 ft/lbs TQ, 199 HP.
    Quote Originally Posted by nadthomas View Post
    Man, I'm glad you figured that one out for us, that has been such a road block.
    NECO Member Gold Member StuartGrant's Avatar
    2009 Jul
    Mt. Clemens, Mi
    1,506
    You use the transaxle already in your car.
    You can use engines from;
    Ford Taurus, Mercury Sable 01-05
    Ford Escape, Mercury Mariner, Mazda Tribute 02-05 ish
    Mazda MPV 02-05
    these are the only cars we can use, unless you want to do the leg work to get some other duratec working, and since you didn't even want to read our stickies...
    All builds are rather involved and require an engineering mind set of sorts. No one is going to take the time and spell out everything you'll need to know and have, all the info is in the stickies and build thread, start your research. That said you need to figure out which kind of build suits you and your local best. In areas where you need to visually pass inspection things like full 3L's and EGR deletes are a bad idea, but if not these can save you a lot of work.
    A new exhaust would be a good idea, at least cat back. You can do a completely new exhaust for a little over $1k, that's headers, y pipe, high flow cat, flex pipe, cat back. Check out trubendz and MSDS for these products.
    00' MTX 2.5L, spruce green: Died 9/13/11 - Revived 6/1/12
