I definately do!!! (I knew their would be a lot going into this, but had no idea how deep the rabbit hole went unfortunately)
It did come w/ a tune, but unsure if the tune is correct or not, (also came w/ the xcal 2, I restored it to stock, and it ran worse so I put the tune back on)
I was aware of the vavle cover vent, I knew that needed changing back to original setup. (I didn't exactly know what effect that would have so thanks)
I haven't taken the injectors out, but I was *told* that its running 3L injectors, and it looks to be a 3L fuel rail, and a stock 2.5L fuel rail cut up and mated together w/ some rubber fuel hose and some hose clamps.
Lots of work to go into this kitty...
btw, what throttle cable should this be using... (it has a stock 2.5L throttle cable on it now which looks to be cut, mangled and spliced to work)
(anybody have one laying around? if so PM me.)
