Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 33
Thread: Full Oval Port 3L Swap How-To
    NECO Member 96blackse's Avatar
    May 2003
    Ottawa, Ontario
    382
    Post Full Oval Port 3L Swap How-To
    Hopefully this will help some people looking to do a complete oval port swap...
    Starting off with the Escape engines
    -If you start off with an Escape engine you will need an oval port plastic Taurus UIM with the Taurus TB bracket
    Starting off with the Taurus Engines
    -If you start off with the Taurus engines you will need to get a new updated escape oil pan, dipstick and oil pick up tube, or you may use the stock oil pan from your 2.5L along with the dipstick and oil pick up tube... There have been some changes to the design of the oilpan's so you are better off getting the newer ones
    -You will also have to swap over the timing covers and the crank pulley from the 2.5 since the Taurus ones will not work...
    -I prefer to use the Escape fuel rail since it’s much bigger than the Taurus one, so if you decide to go with a Taurus engine you might want to grab an Escape fuel rail, it also makes the modification a little bit simpler...
    -The top passenger side engine mount has to be fitted onto the Taurus engine as well. Again, you can either use the one off of the 2.5 and grinded it up so it fits onto the engine with out taking the heads off or buy a new one which will need grinding as well… (the newer ones will need a bit less grinding) Also depending on the year of the engine there are 2 different sizes bolts which hold the mount in place, make sure you use the proper ones
    If you want to use SVT cams on both engines
    -If you are going to use the SVT cams you need to either use all the existing timing components from the 2.5 block or buy new proper timing equipment which consists of the crank sprocket, tensioners, guides and chains…
    You cannot mix and match any of the older and newer equipment… “timing gears went from a 36-tooth camshaft gear to a 42-tooth camshaft gear and were used in the Escape/Tribute all the way through 2005”
    Same for Taurus and Escape Engines
    -If you are planning on keeping EGR you need to modify the tube for it to fit
    -Trim the 2 brackets off the block for the alternator bracket (take your alternator bracket off of the 2.5 and try to bolt it up to the 3.0 then you will see where you have to do a little trimming)
    -Take out the pilot bearing off the crankshaft. This can also be cut flush. While cutting make sure you protect the metal shavings from getting to the rear crank seal, this can be done by masking it off and cleaning after the cutting is done
    -Extend the wires for the EGR solenoid and TPS sensors... If you decide to delete the EGR you can delete the solenoid as well since it won’t be needed. You will just have to run the small vacuum lines for the fuel pressure regulator, HVAC, and EVAP.
    -Enlarge the hole for the throttle cable to fit the throttle linkage, you will see once you try to put the end of the throttle cable on to the throttle body
    -Modify the Taurus TB bracket so you can use the contour cable, this is pretty simple once you have the parts on hand
    - If you have a return fuel system, run the return line for the fuel rail, make sure you get it welded up by an experienced welder and pressure test it before driving around with it
    -You will need to run the oval port injectors since the spray pattern between the oval port and split port injectors are different for this you would either have to wire in the EV6 injector connectors or you can buy adaptors from Ford Racing or Fiveomotorsport’s http://www.fiveomotorsport.com/Injector_CONNECT.asp
    -Depending on the year of your vehicle and the 3.0 engine you are putting in you might have to change plugs for the wiring for the knock sensor and oil pressure sensor. Use the knock sensor that came with your 3.0.
    You car will need a tune to compensate for the lack of IMRC, EGR if removed and the oval port injectors.
    3L 13.5@104 GOT OVAL PORTS? Video of my run!
    NEW GCK axles $65 each!
    www.AxlesForLess.com
  2. #2
    NECO Member gamiller's Avatar
    Jun 2001
    Fairfax, VA
    3,004
    Re: Full Oval Port 3L Swap How-To
    Great post!
    If I was building an N/A motor, it makes sense to use the OEM Taurus/Escape injectors in keeping with the oval port of the UIM. Applications requiring high flow injectors, however, are limited to whatever spray pattern is available in the desired rating.
    N/A for now...
  3. #3
    May 2003
    Ottawa, Ontario
    382
    Actually, there was a similar change in head ports in the mustangs so the earlier mustang injectors with the split ports would be better for split port 3.0's and the later ovalish tumble port injectors would be better for the oval port 3.0's
  4. #4
    Feb 2006
    15
    So, once the fuel rail is modified to return, it is still acceptable to run the 3L returnless injectors?
    For some reason I thought there was a problem with this.... am I wrong?
    Thanks..
  5. #5
    May 2003
    Ottawa, Ontario
    382
    Injectors are injectors, return/returnless doesn't matter its only a change in the plug style... You will just have to splice in the connectors from the wiring harness which came with the 3L or use adapters which I mentioned in the initial post to be able to use them
  6. #6
    Feb 2006
    15
    Quote Originally Posted by 96blackse
    That's what I'd always figured, injectors are injectors. However, after reading through thousands of posts, it argues both ways. Some people swear they are not interchangeable, it will cause problems, etc. I'll take your word for it, you've got the experience. If it works for you, it'll work for me.
    Thanks for clearing it up 100%.
  7. #7
    be trollin fer trolls Lifetime Platinum MemberAdministrator FastCougar's Avatar
    Nov 1999
    Kearneysville, West Virginia
    8,409
    While that is true to a point, it's a bit of a blanket statement ... different injector types have different spray patterns, which are hand picked/speced for their particular application. The type you are referring to is "return" vs. "returnless", which you are correct about, there isn't such a thing.
    Former owner of a 1999 Mercury Cougar - Turbo'd 3L.
    For Sale: 17" Kazera KZU w/Avon Tech M550 A/S 225/45ZR17 tires - $700 + Shipping
  8. #8
    Feb 2006
    15
    FastCougar, very true.
    As you said, we are only comparing return vs. returnless.
    There is most def. a difference between spray patterns based on setup. To compare, there would be a totally different spray pattern on split port vs. oval port. I was aware of this, but thanks for covering it.... posts like this mean when you search, you get an answer.
  9. #9
    NECO Member mj_2284's Avatar
    Jun 2008
    32
    black horse didn't you have pictures to go with your step by step 3.0l swap? if so can you post them again!
  10. #10
    NECO Member 99Mystique's Avatar
    Jul 2006
    Rochester, NY
    290
    Anyone running a full oval port on a returnless car? If so, what rail am I going to need and what connectors?
    00 CSVT - 3.0L/HMS/Koni
    99 Cougar - Powered by SVT
  1. My full oval port 3L install thread
    By jonsalty in forum 3.0L DURATEC Performance
    Last Post: 08-25-2010, 02:37 PM
  2. GB: PnP oval port to split port heads!! $995!!
    By Kinger in forum Group Buys
    Last Post: 09-28-2006, 01:00 AM
  3. Another 3L oval port dyno...
    By Blackcoog in forum 3.0L DURATEC Performance
    Last Post: 05-02-2005, 01:07 PM
  4. 3L Oval Port dyno....
    Last Post: 04-26-2005, 10:36 PM
  5. Replies: 16
    Last Post: 11-29-2004, 09:02 AM
SEO by vBSEO
