Old 04-24-2008, 10:39 PM   #11 (permalink)
devildog's Avatar
Images: 1
Re: High rpm hesitation and loss of power..
Sounds like you are simply hitting the rev limiter nothing more.
devildog is offline
Old 04-25-2008, 08:26 AM   #12 (permalink)
GTownCougar's Avatar
But its an ATX...it should shift before it bounces off the rev limiter repeatedly. Something is still not working correctly.
~2001 Cougar 2.0 MTX~
~Aussie Headlights
GTownCougar is offline
Old 04-26-2008, 11:03 AM   #13 (permalink)
Naturaltal3nt's Avatar
i had same problem with my car however your car is a racecar if your hitting 7-8k rpms. wow where'd you get your cougar? i replaced my plugs wires fuel filter and used some injector cleaner and it went away as far as i could tell. i don't try and redline my car on a daily basis but the last time i did get near it no hesitation. so start there then be my guiney pig and race around tell me if it stops
Naturaltal3nt is offline
