Void Warranty on Precats?
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Void Warranty on Precats?
    2003 Jan
    287
    Could they void my warranty if they saw i had gutted my precats?
    2002 Black Cougar 35th
    - 5-Speed, Mods started, but not far.
    (Last Car) 2001 Green Mustang GT / 5-Speed
    NECO Member madgeo's Avatar
    2003 May
    204
    RE:Void Warranty on Precats?
    I talk to a tech from the deal and they said they can, but like the guys from where I'm at the said what they don't know won't hurt????
    Even the tech said he would help me if I needed the help [img]custom_images/emoticons/shocked.gif[/img]
    2000 Oct
    Minneapolis, MN
    7,485
    They shouldn't be able to tell at a quick glance. The only give away are the MIL eliminators that you would need to stop the engine light from coming on.
    Click here to see my Cougar.
    2003 Jan
    287
    RE: Void Warranty on Precats?
    My mom talked to some guys that were saying they would void the warranty for even an exhaust...so I dunno if i should gut the precats anymore.
    is a pop sensation Lifetime Platinum MemberModerator sonza68's Avatar
    2001 Jan
    Right behind you
    13,612
    Obviously it will void your emissions part of the warranty since you are removing two cats, but it should not affect the rest of it.
    Just because I don't care doesn't mean I don't understand.
    NECO Member EdgeCat's Avatar
    2000 Oct
    2,278
    I'd probably hold off if I were you. I know I fought with CELs for awhile afterwards, and if I brought it in to the dealer for them to fix, I'd have been discovered (engine codes would point to the O2 sensors). I waited until my warranty had expired before I did mine.
    1999.5 Audi A4 2.8QM: Stock... for now.
    2002 Jun
    Columbus, Ohio
    19,961
    Nah, you have a 2002- you don't even need MIL eliminators. As long as you do a clean job, you're fine.
    00 Roush Cougar 03 SVT Focus #2370 08 Mustang Bullitt # 5389
    B3NN3TTCougarDBCarDomainFacebookdeviantARTLast.fmTwitter
  9. #8
    2003 Jan
    287
    Does that mean i should weld over the hole? I don't have a welder handy, but i might be able to get someone to do it for me.
  10. #9
    ShadowGrey
    Guest
    I have a 02 and I went ahead and did it. From what I have heard is that you will void your emmisions warranty (becasue you just cut have it out), but the rest of your cars warranty will be intack. It the burden of the dealer to prove that you modification damaged the warrantied part. They are going to have real tough time proving your alternator, for example, failed because you gutted you precats. Even with engine troubles, it would be really hard for them to claim the precats were the source of the problem. Here is a link to some info.
  11. #10
    Moderator Moderator EricF's Avatar
    2000 Oct
    Wildwood, Florida
    5,104
    You would nullify your exhaust warranty.. and they would only be able to tell
    if you brought it in for an emissions related claim..
    Now remember it is a federal offense to alter your emissions control devices...
    I've never heard of someone getting busted for it though...
  1. void warrenty ????
    By astunnabybirth in forum Transmission Performance
    Last Post: 2006-03-07, 03:12 PM
  2. will adding a y pipe void my warranty???
    By jason01cougar in forum 2.5L DURATEC Performance
    Last Post: 2003-10-26, 04:10 AM
  3. What mods will void your warrenty?
    By PappaSmurf in forum General Info
    Last Post: 2002-08-24, 02:06 AM
  4. adding intake/exhaust void entire warranty?
    By Etack in forum General Info
    Last Post: 2002-08-01, 08:37 AM
  5. warrenty void?
    By RicciHull in forum 2.5L DURATEC Performance
    Last Post: 2001-04-17, 08:56 PM
