Odd engine observation
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: Odd engine observation
    2000 Nov
    2,113
    Ok so I took my UIM off this past weekend because my engine was acting screwy. Now its fixed
    But here it goes. I think its cylinder 6. The front drivers side cylinder, not the secondary one the smaller opening one. When I looked at it, it was SPOTLESS. Every other port was dirty like its suppused to be. But you could serirously eat off this port. Both the UIM and LIM port was clean only on that cylinder. The secondary port was dirty like the rest.
    Very odd huh?! I have no CELs or anything so its not like that one isnt working, plus the secondary port is dirty. Ohwell, any ideas? Anyone ever seen this?
    Tony
    El Mucho Post Whoro Administrator NorCalCoug's Avatar
    2001 Nov
    SF Bay Area
    12,869
    Magic cleaning gremlin living in that port? All the rest of them got sucked in and died but this bastard has hella good grip.
    2000 Nov
    2,113
    thats what I originally thought, But I couldnt find the little bastard.
    NECO Member caenus's Avatar
    2001 Apr
    2,838
    Maybe he is stuck in the precat material if he made it through the engine
    2000 Tourmaline Green V6
    [ CougarDB.com/caenus ]
    2001 Oct
    Madison, WI
    815
    Thats really odd... havent seen that before. Id say if it was a piston that was that clean, youd have a head gasket out between a coolant passage and the cyl. nooo idea on that one though.. unless your UIM had a sereous restriction to that port.
    2006 Subaru Impreza STi
    Cobb 3" cat-back, Group N motor, trans, pitch stop mount, Whiteline diff bushings, RaceCompEngineering camber plates, Group N rear strut mounts, KW variant 3 coilovers.
    Burn-Up WRC replica hood, bumper, and carbon lip, WRC side mirrors, center gauge pod, EGT, boost, and oil pressure gauges, Prodrive mud flaps, Spec-C roof vent
    2001 Oct
    211
    LMAO!!!!! Clogged fuel injector?
    2000 Nov
    2,113
    Well I have an SVT UIM and SVT LIM with all new injectors. The secondary port is dirty so if the fuel injector wasnt working than the secondary would be clean too right? I have no precat material cause i have headers. So that gremlin could be anywhere.
  9. #8
    2000 Oct
    728
    i noticed the same thing on mine. its not spotless but it is a lot cleaner than all the other ports.
  10. #9
    PacmanTravis
    Guest
    I dont mean to post off-topic, but NorCalCoug, why is it that most people that say "hella" are from norcal? I went to school up there in monterey, and it was "hella this, hella that" Now, when I came back down to SoCal...hella is nowhere to be found
  11. #10
    2001 Nov
    SF Bay Area
    12,869
    'Hella' is a NorCal thing. It has since spread, but it's still a NorCal thing.
    Here's the thing though, right? The oil suspended in the intake air (from the PCV) is what's gumming up your intake manifold, not the injectors. Secondaries are usually dirtier than primaries because the butterfly valves aren't always open, trapping that oil-suspended air in the runner for a bit longer than normal, coating the runner with an oil varnish (over time). But that doesn't explain why the primary was completely clean unless there's a dead animal stuck further up in the runner.
  1. Just an observation
    By Rhino in forum Politics
    Last Post: 2008-10-16, 09:05 PM
  2. An Observation
    By doogo99 in forum General Info
    Last Post: 2006-11-13, 12:36 AM
  3. even or odd fire engine?
    By dugiefresh484 in forum Problems
    Last Post: 2006-01-22, 02:38 AM
  4. Odd popping noise from the engine area...
    By JScullin in forum Problems
    Last Post: 2005-11-15, 06:54 AM
  5. Odd Engine Noise when Defrosting :)
    By Teflonworm in forum Problems
    Last Post: 2005-01-02, 02:01 PM
