No Cats + No secondaries = GROSS POLLUTER
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: No Cats + No secondaries = GROSS POLLUTER
    2001 Feb
    2,163
    Well, I took my car in for inspection today... ummm... it was ugly.
    NOx:
    Standard: 625
    Reading: 2182
    Result: FAIL
    HC:
    Standard: 78
    Reading: 99
    Result: FAIL
    CO%:
    Standard: 0.44
    Reading: 0.98
    Result: FAIL
    Luckily, it passed for:
    Tampering: PASS (hahahaha!)
    Visible Smoke: PASS (they didn't floor it )
    Looks I'll be needing to bolt a cat on...
    -2003 Mustang GT 5-Speed. 4.30 gears, full exhuast, C&L Intake plenum w/ 75mm TB, SCT Tuned, not yet run!
    -1994 BMW 525i Auto. I don't drive it unless I have to.
    SOLD: 2003 Mustang GT 5-speed, 4.10 gears, full exhaust, bolt-ons - 13.70 @ 102.73
    SOLD: 2000 Cougar V6 Auto. Full exhaust, IMRC delete, SVT upper intake, TB, snorkel, and airbox, suspension work - 15.93 @ 86.97
    NECO Member Prez's Avatar
    2002 Mar
    2,547
    how did you do away with the secondaries?
    NECO Member MaStaMooN's Avatar
    2000 Oct
    BrickTucky, NJ
    2,399
    2005 Subaru Legacy GT - Silver - 5MT
    Mods: Borla Catback Exhaust, COBB AP TDC E-Tune Stage 2T, Cobb Catted Downpipe, Bosal Uppipe, Perrin TMIC, STi STS, 4300k HID Conversion
    NECO Member katnyp's Avatar
    2000 Oct
    1,219
    Why did you even try to get inspected with no cats? They should have arrested you for assaulting their NOx meter.
    '99 V6 5spd, white - I/H/E, Koni/GC, Visteon GFX, 18" Centerline RPM
    148 fwhp / 147 ft lbs - best ET: 15.56 @ 87 mph
    '01 Berlina Black S2000
    '05 Kawasaki Ninja 250
    2001 Dec
    1,185
    Frank, frank, frank *shakes head* Didn't I tell you to just pay the 50 bucks and bring the car to a private inspection place? :-P
    Though I have to say that your numbers are most impressive
    2001 Feb
    2,163
    Yeah, my car always puts out big numbers on the dyno, no matter what it's being tested for
    Ah well... time for a 2.5" high-flow cat. I figure that for only a little more money than it would cost to pay off a private inspector, I can fix the problem... The car might actually run better than it does with the 2.0" straight-piped cat!
    2001 Feb
    2,163
    Just removed the rods and butterflies...
  9. #8
    NECO Member exigent's Avatar
    2000 Oct
    Clarkston, Mi
    1,761
    What about the holes left were the rod goes through the side of the intake tract..... the inner holes will allow BAD turbulance and the outer holes will allow a SICK vaccume leak.... i can only assume you pluged them somehow...
    Missing the old days...
    I was here (or on ezboard rather) when all you could do to a Cougar was a KKM intake and a Borla.
  10. #9
    2001 Feb
    2,163
    The outer holes were plugged, of course. The inner holes don't look like much of an issue to me
  11. #10
    2000 Oct
    1,503
    NOx:
    Standard: 625
    Reading: 2182
    [img]custom_images/emoticons/shocked.gif[/img]
    Good God man!!
    What did they say to you?!?
    GO RAVENS!!
    T.O. is a b!tch!
  1. Just gross.
    By marinofan in forum The Lounge
    Last Post: 2008-07-05, 08:19 PM
  2. Gross!
    By Tygerr in forum Ohio NECO
    Last Post: 2007-07-17, 01:41 AM
  3. I think I've come down with SARS (gross pictures..)
    By EricF in forum Keystone NECO
    Last Post: 2003-05-31, 11:19 PM
  4. Gutting cats ? pre-cats ? Main cat ?
    By ttawd3s in forum 2.5L DURATEC Performance
    Last Post: 2003-04-28, 03:30 PM
  5. Gross Misrepresentation
    By AfterBurner in forum Wisconsin NECO
    Last Post: 2001-12-06, 02:53 PM
