Dual Mode Dampener, is it worth it?
Results 1 to 7 of 7
Thread: Dual Mode Dampener, is it worth it?
    NECO Member rastaman's Avatar
    2000 Dec
    2,959
    I know what they do, but is it something that is only necessary if you're pushing high horse power applications? Is it lighter than the stock one? How hard is it to install?
    God Keep Our Beer, Glorious and Free! O Canada, We Drink All Night For Thee!
    NECO Member Wayne7497's Avatar
    2002 Apr
    369
    But heavier than the stock one i think... And easy to installl... just take off wheel pull off wheel well inside cover untensions belt pull off with puller bolt on DMD and retension.... Should be it...
    Wayne T
    Eibach Cougar Ebony Black,MTX, 17" Roh Azzurro Wheels...With Dunlop Fm 901's 17x8x235... 20% Tint..Stainless Steel CatBack twin with Stainless Steel Headers from Dt Performance.... ASP UD pulley installed PowerChips Aus PowerGold 98....Full Visteon Body Kitt installed with Razzi 00 rears. Vtech Tail/Headlight Covers..
    2001 Dec
    1,185
    It's heavier than the stock one (hence "dual mass")... But if it's heavier, doesn't it actually hinder performance slightly?
    NECO Member ricecats's Avatar
    2001 Oct
    440
    In theory it's that simple. However do the process right.
    Use a NEW crank bolt since it is one time use only bolt and torque to proper specs. Just slapping a new one on without using a new bolt or proper tq specs will cause problems.
    NECO Member MrFroge's Avatar
    2000 Dec
    Patterson CA
    2,615
    IMO - I would think that if the dampener is heaver then it would adversely affect the performance.. I'd think an ATX would never get off the line..
    NECO Member DemonSVT's Avatar
    2001 Oct
    2,112
    The DMD is ~1lb heavier then the stock damper. However being a small radius unit the change due to weight is negligable at best.
    Matter of fact it is more likely to make more power in the upper rpms since the crank whip, flex, & vibrations are lessened.
    My 2000 SVT Contour
    13.47 @ 102mph - All Motor
    2000 Oct
    1,421
    Ford doesn't seem to think that its only for high power applications. They redesigned it for the run-of-the-mill 170hp 2.5L. The DMD is so worth it. The engine is so smooooooooth now and it feels like it revs slightly quicker. I'm truly surprised of how much vibration there was previously. Also, power comes on more evenly now as the engine revs.
    They're about the same. The DMD is only slightly heavier. It's negligible.
    I got mine installed at great Ford dealership that I trust completely since I had no time to do it myself. Cost me $82 Canadian ($50 USD) to install it at my Ford dealer (1.1 hours). They said it was a piece of cake. Terry told me that some whacko Ford dealership on the US east coast was charging $250 USD for installation. I highly recommend getting them from Terry. The whole transaction only took about a week which is very good for something ordered from the US to Canada. The shipping itself only took only two days. The price is only slightly more than BAT.
    Fernando Gomes Semedo
    Cougar V6-5spd
    FordEurope.net | FordEurope.net Forums | NAEFR
  1. Dual mass dampener
    By Freedom Fighter in forum 2.5L DURATEC Performance
    Last Post: 2008-02-12, 04:46 PM
  2. Harmonic Dampener
    By Gorman in forum 2.5L DURATEC Performance
    Last Post: 2006-03-15, 10:29 AM
  3. dual mass crank dampener?
    By Gebby in forum 2.5L DURATEC Performance
    Last Post: 2005-06-25, 02:46 AM
  4. Dual Mode Damper (DMD) for $65
    By Icefury in forum General Info
    Last Post: 2003-04-11, 12:12 PM
  5. DMD (dual mode dampner) for $85
    By Cat88Extreme in forum 2.5L DURATEC Performance
    Last Post: 2003-02-03, 07:17 PM
