Old 03-17-2006, 03:12 AM   #61 (permalink)
nel1551's Avatar
Re: SVT Upgrades- By request
I have a 2000 cougar....its a atx and I was wondering what cables I would need if I replaced the uim and tb with a svt uim and tb?
nel1551 is offline
Old 03-17-2006, 04:56 AM   #62 (permalink)
michcougar's Avatar
Dude you posted in the proper topic, dont be lazy just read
its at the top of the page. Here you go!
Originally Posted by DanG
<u>ATX Users:</u>
A request from a member asked what is needed if you have an ATX Cougar performing the "SVT Upgrade Lite" mods:
-You will need a cruise control cable instead of a throttle body cable. The ATX Cougars have identical throttle cables to the SVT Contours, whereas the MTXs have the same cruise control cables as the SVT Contour. So either way, you need a cable- It just depends on your transaxle type as to which you need.
michcougar is offline
Old 04-09-2006, 10:14 PM   #63 (permalink)
spyder44's Avatar
SVT Upgrade FULL
-SVT LIM ~75
-SVT UIM ~400
-SVT TB ~120
-TB Cable ~20
-TB Bracket ~40
-Gaskets ~250
-SVT Heads & Cams ~450
-SVT 19# Injectors ~150
-SVT Pistons ~150
Added by DanG:
-New rings, block hone (must do if changing pistons- Realizing that you've torn the complete engine down and handed it to a machine shop for this kind of work) ~400-500 with labor
-SVT ECU to properly handle the 19# injectors, pistons, & cams ~75
-PATS re-key at your local dealer to have the ECU recognize your keys ~50
~$2280, SERIOUS labour
Added by DanG: Total power increase expected: Full 30hp at the crank if using 2000 SVT pistons (10.25:1)- 25hp if using '98 or '99s (10.0:1)
I have been looking around on the SVT upgrades and i was wondering if it would be easier to just swap the cougar 2.5 for a 2.5 SVT from a contour w/ ECU? It would be cheaper according to the price you listed above and have the same gains as the 3.0 swap (both have ~200HP according to autotrader.com). You can pick up a SVT Duratec 2.5 on Car-part.com with 75,000 miles on it for $1000.
An escape 3.0L for ~$1,000 +whatever you have to buy/do to make it work with the cougar. The SVT 2.5 should be: a little cheaper, the same HP results (not sure on the touque), and a little less work i think.
Im sorry if this has been already posted but i searched and found nothing.... Just an Idea!!!!!!!!!!!!!!!!!!!!!!
Silver Frost 2000 MTX Cougar:
Autotrader page
Dual Exit Borla Exhaust & Trubendz Testpipe
spyder44 is offline
Old 04-09-2006, 10:48 PM   #64 (permalink)
3L Power
mond12345's Avatar
Images: 14
No not really. If your going to just swap the motor go with the cheaper, more powerful 3L.
Heavily Modded
mond12345 is offline
Old 04-10-2006, 12:46 PM   #65 (permalink)
spyder44's Avatar
From what I have searched and read they both seem to have the same power output. I'm not trying to argue or anything but I’m just trying to point out that this might be an alternative route to doing all of the “serious labor” listed for the "SVT Full" upgrade or the 3.0 Swap.
Maybe I'm thinking about this way to hard lol.... seems like a good idea.
Reasons for my speculation;
SVT 2.5 L(basicly)
Originally Posted by 99ADCCOUGAR
What I have put in
SVT:
*UIM
*LIM
*CAMS
*GEARS
Unorthodox Racing:
*Pulleys
ADC:
*2.5 NA Chip
Zex
*50 shot
q
Vs.
Originally Posted by Echoman
3.0 hybrid with P&P'd heads with 3L valves, SVT cams, UIM AND LIM ALONG WITH TB. Weapon R headers to highflow cat and Yodude dual exhaust setup,GMK CAI, oil cooler, spec stage 3
Autotrader page
spyder44 is offline
Old 04-19-2006, 07:34 PM   #66 (permalink)
Pompous Libtard :)
BigBalledOX's Avatar
Images: 51
K, I spell this out for you. The TOP dyno plot has a 50 shot of NITROUS on it. The bottom dyno plot is a normally aspirate 3L.
You are comparing apples to oranges.
Even if you go a simple, stock for stock swap the 3L is the better choice. SVT engine is rated 195 hp/170 tq. 3L engine is rated 200 hp/200 tq.
The 3L is far and away the better choice if you are swapping engines.
Basically, Kraft Dinner is to Canadians what fried chicken is to black people, or rice is to Asians, or *insert other stereotype here*
its a money pit!
BigBalledOX is offline
Old 04-25-2006, 04:21 PM   #67 (permalink)
Zip
Zip's Avatar
I read this thread a fourth time and found the info I was looking for basically, my post below Claymore's is my new one I'm editing.
Cougar Database Profile
1996 White Ford Mustang SVT Cobra 5SPD
2000 White Mercury Roush Cougar ATX
Zip is offline
Old 04-25-2006, 05:50 PM   #68 (permalink)
ClaymoreWW's Avatar
by no means am I an expert on these matters, but I will mention a few things that may cause you to have issues. The SVT engine needs the SVT ECU (or a replacement chip). The SVT ECU is set up for a manual transmission. Also, I am pretty sure that the SVT engines were return style fuel lines and your Cougar may be returnless. On the other hand, it should be a direct physical swap.
Anyone feel free to correct me - I won't get upset.
--george
2000 Rio Red 2.5L MTX - see mods in links
CF2K6 - 3rd Interior, 3rd Exterior --- CF2K7 - 2nd Interior, 3rd Exterior
Me on CougarDB - Me on TeamNECO - Me on MotorTopia
ClaymoreWW is offline
Old 04-25-2006, 11:24 PM   #69 (permalink)
Zip
Zip's Avatar
Actually you just summed up my entire post into 3 lines. I often fluff up my posts with wording I don't need. Thanks for your reponse, looking for confirmation on it by others possibly.
That's basically my three questions:
1. ECU. I am an ATX, If I get an ADC Chip and have them program it to my mods and the 2000 SVT Engine it will work? My biggest fear is probably the smallest. Installing the engine and then going "oh it won't start uh oh." (Also, there are two chips listed @ $300 dollars on their site, I mention this later.)
2. I have a returnless style fuel system, the SVT in 99 at least was return, how much work is it to make this work in my car? Or is it still just a direct physical swap and the chip does it all for me; Or is there some minor modifications that need to be done on a the fuel system?
2b. If I just get a 2000 SVT engine I'm fine fuel system wise no matter what as the injectors are the exact same as what I have.
3. If it is a direct physical swap, there should be no issues I assume besides getting a chip for my Stock ATX ECU that adapts to the SVT. I see ADC sells these on their site. http://www.arizonadynochip.com/Templ...D=7&SearchYN=N . Do I need the SVT contour one or the 2.5L Cougar/Contour one. I assume the SVT Contour since it's the same engine? I would NOT need the rekeying since I don't have a new ECU since I would have a chip because of my ATX ECU with an ADC chip. The only other thing I can think of needing for the swap would be the cable for my cruise control since my throttle cable is the same apparently!
Is there anything else I should know, this sounds simple and I have the money. I'll have a shop do the install probably, I just want to make sure I've covered everything before I drop a thosaund dollars on a total engine and then find out I need another thousand in a bunch of other crap. Might as well have headers put on it while I'm at it I guess. There are some pretty cheap / low mileage engines within 200 miles of my house that are listed as running great and I've done everything to the exterior of the car I could ever want. It's time to actually make it move.
Zip is offline
Old 04-26-2006, 09:10 AM   #70 (permalink)
Man if you're dropping a grand on an engine why are you buying the same effing engine you already have ...
2000 ATX V6 "C/ZN" (Silver Frost) - SOLD 5-23-08
2006 Mustang 4.0 - Legend Lime w/ Black Stripes
AnthonyP is offline
