Car won't start again problem is back!!!
Page 3 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 21 to 30 of 95
Thread: Car won't start again problem is back!!!
  1. #21
    be trollin fer trolls Lifetime Platinum MemberAdministrator FastCougar's Avatar
    1999 Nov
    Eastern Panhandle, WV
    8,297
    Things that I would double-check:
    1. Check and recheck ALL vacuum lines going to the UIM!!!
    2. Make sure that the IACV is operational
    3. Make sure that the MAF and IAT are plugged in
    4. Make sure you have gas
    5. Confirm that the plug wires are going to the proper plugs and coil
    6. Confirm that the plugs/wires are firing using one of the methods described above
    That is all I can think of now ... keep us updated, and good luck!
    Former owner of a 1999 Mercury Cougar - Turbo'd 3L "Mavro Gato".
    For Sale: Turbo Cut Heads (w/SVT cams), All New Timing Equipment - PRICES SLASHED!
  3. #22
    King Julian Lifetime Platinum MemberSuper Moderator ov3n's Avatar
    2000 Oct
    Milwaukee, WI
    8,094
    I started my car once with those 2 vaccum lines not connected to the UIM... the car idled real weierd and made a whistling sound. it was cool.
    Quote Originally Posted by BBOX
    TELL ME NOW YOU MAGNIFICENT SON OF A B¡TCH
  4. #23
    NECO Member MaStaMooN's Avatar
    2000 Oct
    BrickTucky, NJ
    2,397
    I know you smell fuel, but have you checked your fuel cut off switch that is located under the driverside dash?? Maybe this got popped somehow when you were working on it.. Worth a check.
    2005 Subaru Legacy GT - Silver - 5MT
    Mods: Borla Catback Exhaust, COBB AP TDC E-Tune Stage 2T, Cobb Catted Downpipe, Bosal Uppipe, Perrin TMIC, STi STS, 4300k HID Conversion
  5. Remove Advertisements
  6. #24
    T3/T4 60-1 PuckPuck's Avatar
    2000 Oct
    Windsor, Ontario, Canada, 108634965827573, Windsor, Ontario
    8,015
    the fuel cut off kills the fuel pump... if he hears the fuel pump the fuel cut off would be not the issue.
    also you can run a car without egr, iac and iat... it will just idle horribly... you can even leave the vacuum lines on top the uim disconnected, again you'll just get a horrible idle and some unmetered/unfiltered air entering the engine (not to mention 0 braking power)
    PuckPuck.Com
  7. #25
    NECO Member StreetConcepts's Avatar
    2000 Oct
    3,751
    Pulled teh plugs and they were drenched in fuel.
    turned the car over to get rid of that extra fuel
    replaced the plugs with brand new ones
    car will not start and looks like I have no spark.
    Cannot figure out how in the world a working car can have a toasted coil pack just fromtaking it apart and reassembling it.
    https://www.facebook.com/craig.flango
    1999 Mercury Cougar V6 Turbocharged
    2008 Mitsubishi EVO-X GSR
    2005 Nissan Murano Airbagged
  8. #26
    2000 Oct
    3,751
    Here is a pic of the black plug located at the back of the coil pack on the passenger side. can someone check the lead coming off this plug and tell me if it is supposed to be a ground? Mine does not show ground
  9. #27
    2000 Oct
    3,751
    Here is a pic of the plug itself.
    Tested it with a meter and there is no continuity from the bolt side to the wired lead. Also checked for resistance and it is wide open.
    part # f6af-18801-aa this come up in any of the ford cd's?
  10. #28
    2000 Oct
    3,751
    anyone else have any idea's? I located a used coil pack at a salvage yard in Mansfield PA roughly 45 mins away for $60 but want to make sure I have covered all the bases first
  11. #29
    2000 Oct
    8,015
    warmonger on the CEG has a thread called Stuttering problem in the 3.0L category, his problem ended up being something to do with a ground on the coil pack... i would definetely let him know about this.
    PuckPuck.Com
  12. #30
    1999 Nov
    8,297
    If the spark plugs where soaked, this means that fuel was probably in the cylinder for the past 48 hours since this problem has been going on since day before yesterday. I mention this beause fuel has probably contaminated your oil. CHANGE YOUR OIL once the car is operational again. Sounds like the problem is the coil from what you have posted. What does that plug plug-into? Trace that wire and see.
  1. Car won't start, maybe a starter problem
    By Dakota in forum Problems
    Last Post: 2008-10-28, 12:21 AM
  2. Replies: 4
    Last Post: 2005-03-02, 11:48 PM
  3. Car won't start!!
    By Warriorvx in forum Problems
    Last Post: 2004-12-09, 11:35 AM
  4. Replies: 5
    Last Post: 2004-01-09, 05:30 PM
  5. Car won't start
    By zybo2004 in forum Problems
    Last Post: 2001-11-10, 11:23 AM
