looking for replacement dpfe hose to tube connections
Results 1 to 7 of 7
Thread: looking for replacement dpfe hose to tube connections
    NECO Member D-RON12783's Avatar
    2011 Dec
    Decatur, TN
    22
    Question looking for replacement dpfe hose to tube connections
    my 2002 cougar 2.5L V6 has a bad dpfe sensor. so i'm going to replace it but i need the two high-temperature hoses that connect to the high and ref fittings on the egr pressure tubes. does anyone know where i can get these two hose replacements or how i can use a metal tubing connection set-up?? thanks (this is my first post on the site and many more to come and reply to also)
    ...did i dooo thattttttttt....
    2011 Dec
    Decatur, TN
    22
    Re: looking for replacement dpfe hose to tube connections
    also i'm looking for a vaccuum diagram of lines for my cougar as well.. any diagrams would be a great help!! thanks
    NECO Member Gold Member Tygerr's Avatar
    2003 Mar
    Lexington, KY
    9,336
    I was unable to find those lines, so I ended up just using some automotive vacuum hose from AutoZone. It's held up fine to the heat.
    I found I had to keep the hoses very short, otherwise the sensor got an improper reading and I'd throw a code.
    Buckeye @ heart
    35th Anniversary Cougar Satin Silver
    06 Legacy 2.5i Limited
    "Make sure the government runs good." -William Henry Harrison
    2011 Dec
    Decatur, TN
    22
    what about using some metal fittings/connectors to eliminate the use of rubber hoses.. does anyone know if that is possible.. i think i read on the forum somewhere that someone did away with the rubber hoses.. id like to do the same..
    NECO Member mmc757's Avatar
    2010 May
    Norwich, CT
    1,565
    Could probably be done with some 1/4" stainless tubing, but you would still need to make the final connection to the dpfe with rubber hose.
    Not much point in reinventing the wheel here...less brain damage to just replace with oem parts from the JY and some new high temp hose from the hardware store.
    Klaatu barada nikto
    2011 Dec
    Decatur, TN
    22
    what is the max temperature these hoses need to be.. i dont need any more stessors cuz im bout to drive the car 6 hours to SC from Tenn.. thanks..
    2000 Oct
    Minneapolis, MN
    7,473
    Did you try the dealer? Otherwise get some high temp hose from an auto parts store.
    Click here to see my Cougar.
