SVT ecu/pcm
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: SVT ecu/pcm
    NECO Member vman's Avatar
    2011 Mar
    Castro Valley, CA
    130
    Question SVT ecu/pcm
    Ok this isn't about how it works or which ones work or anything like that. This is simply the question of where can i find one (and for a decent price) or if i need to even find one. So things fell into place and making my 2.5 svt and i have everything i need except for the ecu I have a WTB ad in the forms and no replies everywhere else I have looked has just been impossible to find a good one let alone a decent price. i was just wondering if anyone knew where to get one or what it takes to tune a regular mtx ecu to svt and if so where i could get an mtx ecu? Thank you.
    NECO Member aboythatskates's Avatar
    2010 Mar
    spokane washington
    2,982
    Re: SVT ecu/pcm
    they pop up once in a while and go just like that.
    quickest and easiest way:
    buy a running peice of **** for 300$ off craigslist, then drive around til u find a svt driving on the road and total it with ur pos. then u can take the ecu.
    Full 3L '99 Mercury Cougar MTX.
    195 ft/lbs TQ, 199 HP.
    Quote Originally Posted by nadthomas View Post
    Man, I'm glad you figured that one out for us, that has been such a road block.
    NECO Member MidOH3LCougar's Avatar
    2011 Jan
    Cardington, OH
    1,020
    Re: SVT ecu/pcm
    An SVT ECU will have nothing on a custom tune, so if you have the funds available you should go that route.
    2011 Mar
    Castro Valley, CA
    130
    Re: SVT ecu/pcm
    ok i guess ill keep it in mind the problem is that i dont exactly have the funds but if i have to i will. but i cant remember where i saw it but is the ecu for our car and the contour behind the power steering reservoir because if it is the ecu might still be at the wreaking yard i found the contour in.
    2011 Jan
    Cardington, OH
    1,020
    Re: SVT ecu/pcm
    Yes, you pull the power steering tank, IIRC there is 1 bolt to loosen, then you go inside under the carpet, remove another bolt and it will slide down and out.
    Edit- actually, i dont think you have to unbolt the harness in the engine bay.
    2011 Mar
    Castro Valley, CA
    130
    Re: SVT ecu/pcm
    so wait the ecu is in the engine bay?
    2011 Mar
    Castro Valley, CA
    130
    Re: SVT ecu/pcm
    sorry i just need to clarify this. i always thought it was at the passengers right foot under the carpet like in every other car i know. lol
  9. #8
    NECO Member Tumuerte's Avatar
    2010 Oct
    Windsor, Ontario
    983
    Quote Originally Posted by vman View Post
    Nope. It's not in the engine bay. It's inside by the passengers footwell like you thought. You do however have to go behind and below the steering reservoir to access a single bolt on the middle of the harness connector.
    Sent from my AT100 using Tapatalk
    * 2000 V6 MTX (Black), MSDS Headers + Y-pipe, K&N SRI, Trubendz-Borla, HMS, Torsen, Stage 3 Clutchmasters, Fidanza, 8k's x4, JVC KW-NT3HDT, '01 leather interior
    * 1999 V6 MTX (Silver Frost), Lincoln Sync Nav system
  10. #9
    2000 Oct
    Minneapolis, MN
    7,485
    Re: SVT ecu/pcm
    Even if you find one you can't run it without the keys for that ECU. You'd have to pull the chips out of the keys and swap them into your current keys. Otherwise, you need to have ford program your keys to the new ECU which will be over $100. Get a SCT tune for your current ECU and be happy.
    Click here to see my Cougar.
  11. #10
    2011 Mar
    Castro Valley, CA
    130
    Re: SVT ecu/pcm
    ok so the best bet then is to just get an mtx ecu and tune it?
