3l heads
Results 1 to 6 of 6
Thread: 3l heads
    2011 Dec
    Rockport, Texas, United States, 105634236137071, Rockport, Texas
    64
    3l heads
    will the cylinder heads off of a 3l work on a 2.5 motor
    2011 Dec
    64
    Re: 3l heads
    round port forgot to mention
    2000 Oct
    Minneapolis, MN
    7,473
    Re: 3l heads
    They would bolt up but depending on the year block and year of the heads certain oil/coolant passages wouldn't match up. Compression would drop quite a bit so you'd loose a ton of power. The cylinder and compression chamber would be shaped like a mushroom. I don't know if the head gasket would seal. There really is no reason to do it.
    Click here to see my Cougar.
    NECO Member Gold Member StuartGrant's Avatar
    2009 Jul
    Mt. Clemens, Mi
    1,501
    If by round port he means the split port he'll also have to deal with an electric water pump since those heads lacked the cam driver pump.
    00' MTX 2.5L, spruce green: Died 9/13/11 - Revived 6/1/12
    2011 Dec
    64
    Re: 3l heads
    thats kool i was just wondering it is just stuff that goes threw my head when I'm at work at oriellys
    NECO Member Quatrini's Avatar
    2010 Jun
    just outside of philadelphia
    825
    Re: 3l heads
    as blackcoog said, theres no reason to do it. you'd lose power, gaskets might not seal... ugh. blackcoog covered it all. theres nothing else i can add.
    "Why is it I don't have time to do it right, but always find time to do it a second time?"
