svt cams vs 3l cams
Results 1 to 8 of 8
Thread: svt cams vs 3l cams
    2011 Dec
    Rockport, Texas, United States, 105634236137071, Rockport, Texas
    64
    Cool svt cams vs 3l cams
    which cams would you get more out of the svt cams or the 3l cams just curious
    NECO Member bgrogan01's Avatar
    2010 Sep
    Dallas, Ga.
    29
    Re: svt cams vs 3l cams
    I think most people will say the svt cams are better. There is plenty of info here and on ceg regarding this. I have driven a ported 3L with 3L cams and I have driven a ported 3L with svt cams. Really I couldn't tell a huge difference. With the 3L cams the power and torque come in a little sooner but the svt cams pull harder at the top end. My 98 has a ported 3L with 3L cams and pulls really hard all the way up to the redline.
    - 99 E1 B/MNB #1974 stock DD
    - 98 EO B/MNB #0812 3L Sold
    - 98 EO T-Red/MNB #0322 (totalled)
    NECO Member alley's Avatar
    2006 Feb
    round lake, il
    419
    svt cams give higher top end, while 3L cams give a better midrange. please dont install 3L cams on a 2.5L. I have a set of svt cams in the for sale section if your looking for some.
    NECO Member MidOH3LCougar's Avatar
    2011 Jan
    Cardington, OH
    1,020
    Full 3L with SVT's in mine, top end is pretty good. Havent driven a 3L with 3L cams but most say they are not worth the hassle to swap out.
    2011 Dec
    64
    why not put the 3l cams in a 2.5 you shouldn't smack a valve or anything may just need a tune but shouldn't have anything major happen
    NECO Member aboythatskates's Avatar
    2010 Mar
    spokane washington
    2,982
    a 3L duratec doesnt have 2 runners for each cylinder. the 2.5 does. one is short and the other is long, made for torque and high end power. since the 3l doesnt they have different cams tunes specifically to the needs the the oval ports
    Full 3L '99 Mercury Cougar MTX.
    195 ft/lbs TQ, 199 HP.
    Quote Originally Posted by nadthomas View Post
    Man, I'm glad you figured that one out for us, that has been such a road block.
    NECO Member mmc757's Avatar
    2010 May
    Norwich, CT
    1,567
    Quote Originally Posted by aboythatskates View Post
    This is silly. The mix and match people do on 3l's should tell you that the cams and UIM's arent dependent on each other...its all in the tune. They could be designed to compliment each other, but they are certainly not co-dependent.
    The only guy that tried it screwed up the work, then tried to get away without a tune. The truth is we have no idea how it would perform because nobody else has bothered.
    As for the original question, search and you will find about a thousand threads discussing this topic.
    Klaatu barada nikto
  9. #8
    2010 Mar
    spokane washington
    2,982
    well then why are they even different? ford could have saved time and money by keeping them the same if it didnt matter. but no....they did for a reason
