Are the 2.5L 3 flange Y-pipe/flex and cat interchangeable with the 2 flange on an MTX?
While doing a ATX/MTX swap, someone liberated me of the 2 flange set up. The MTX donor had a two flange set up. My ATX has a three flange system.
Yes you can swap a 3 bolt Y-pipe onto a MTX. I've done it before.
3L 99 Rio Red MTX ,
91 306 Dech Coupe, 08 Escape, 96 Contour, 01 Yamaha R6
Official Member of Ontario NECO, and MC-NECO
PROUD MEMBER OF THE ND4SPD ARMY
www.roadawareness.ca
Thanks. At the Flex pipe, where you able use to gaskets or do you have to go with donuts.
3L 99 Rio Red MTX ,
