how to bypass the o2 sensor
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: how to bypass the o2 sensor
    NECO Member quickkat's Avatar
    2008 Jul
    14
    is there a way to bypass the o2 sensor on my 1999 mercury cougar?? a guy at autozone said sumting about putting a washer on the intake but id rather have you opinion
    NECO Member hubbard2_a's Avatar
    2008 Sep
    MD Eastern Shore
    22
    Re: how to bypass the o2 sensor
    hmm, ther is the MIL eliminator mod. but that goes on the o2 sensors on your exhaust.It tricks the car into thinking you still have your pre cats when they have been gutted or removed
    01 mtx, Borla daul exit, weapon R short ram, mass air mod, pre cat mod , heavey duty clutch, loose screw holding the steering wheel
    kinda went on the back burner when I got the 929 though. cbrworld.net
    NECO Member Tygerr's Avatar
    2003 Mar
    Lexington, KY
    9,288
    MIL eliminator or a tune to get rid of it.
    Buckeye @ heart
    35th Anniversary Cougar Satin Silver *For Sale*
    06 Legacy 2.5i Limited *Sold*
    "Make sure the government runs good." -William Henry Harrison
  5. Remove Advertisements
  6. #4
    NECO Member BlackBetty's Avatar
    2006 Feb
    Lethbridge, Alberta
    7,460
    Putting a washer on the intake?
    Yeha go for a MIL eliminator, you could probably pick one up @ your local exhaust shop.
    New- 2011 Ford Fusion Sport AWD- Steeda CAI/Tune, H&R, Whiteline RSB, LED swap. Fuelly//WheelWell
    Sold-1999 3.0L Mercury Cougar
  7. #5
    Banned
    2008 Apr
    Calgary,Canada
    289
    so its true if i gut all the catalyst material out of my 99 cougar v6 i will have the check engine light on always?
  8. #6
    I love lamp Lifetime Platinum MemberModerator ice992's Avatar
    2004 Mar
    The Woodlands, TX
    2,612
    Quote Originally Posted by tuka View Post
    not if you also install mil elims which trick the computer into thinking its getting the correct readings
    see the how to section.. search mil eliminators
    you can make then for like $3.50 if you can solder if not you can get them on ebay for like $15 shipped i believe
    -Dan
    NECO's How-To PDF Compilation!!!
    @ NorCalCoug
    Also, you hold the phone very dainty. As a lady man would his gentleman lover whilst engaged in a passionate kiss.
  9. #7
    3L Install Maestro Moderator Blackcoog's Avatar
    2000 Oct
    Minneapolis, MN
    7,837
    I believe the washer he was talking about is actually a spacer you put to pull the 02 sensor out of the exhaust pipe a bit. It isn't for your intake. I've heard that for some cars this is enough for the sensors to register normally.
    Click here to see my Cougar.
  10. #8
    NECO Member michcougar's Avatar
    2004 Jan
    Fort Erie, Ontario
    3,174
    I was under the impresion that the o2 sensor had to be working properly when hooking it up to an MIL elim.
    MICH,
    1999 Laser Red 3L Roush Cougar
    2013 Ford F150 3.5 Ecoboost
    2010 Ford Edge SEL
  11. #9
    Sometimes Faster than Dan Lifetime Platinum MemberSuper Moderator B3NN3TT's Avatar
    2002 Jun
    Columbus, Ohio
    22,887
    The ECU uses the O2 sensor's data to control your air/fuel ratio.
    You need those.
    WTF do you want to bypass it for?
    I only wish I had a bigger palm and a bigger face.
    2000 Roush Cougar 2008 Bullitt #5389 2003 SVT Focus #2370 2013 Fiat 500 Abarth
    www.B3NN3TT.com CougarDB CarDomain Facebook deviantART Last.fm Twitter
  12. #10
    2008 Jul
    14
    ok thanks the 02 sensors are on the precats not on the original cat which is gutted out on mine but if i put washers between the 02 sensors it mite work??
  1. bypass module
    By wired691 in forum Audio & Electrical
    Last Post: 2008-03-19, 08:45 PM
  2. bypass unit
    Last Post: 2007-11-16, 05:45 PM
  3. autostart bypass???
    By iceberg65 in forum Audio & Electrical
    Last Post: 2007-11-14, 09:45 PM
  4. Bypass Valve
    By phatcat0887 in forum 2.5L DURATEC Performance
    Last Post: 2004-12-28, 12:08 PM
  5. Bypass MAP Sensor
    By luve10cookies in forum 2.0L ZETEC Performance
    Last Post: 2003-06-13, 02:31 AM
