Old 05-29-2008, 11:48 PM   #1 (permalink)
SpeedStyle's Avatar
Smile imrc relocation
where should i relocate the imrc box, and how?
SpeedStyle is offline
Old 05-30-2008, 01:08 AM   #2 (permalink)
Mass/Conn Mechanic
aircougar1's Avatar
Images: 1
Re: imrc relocation
SEARCH...
SEARCH...
SEARCH...
Seriously, a few people have done it and posted pics....
"YAHTZEE!!!!"
1999 Laser Red Cougar Mtx
R.I.P. Dave Sheehan 2/17/08 The BEST Friend a person could EVER have!!! You were like my Brother, and I will truly miss you!!!
R.I.P. Ray Dagenais 4/15/08 No pain for you in Heaven
aircougar1 is offline
Old 05-30-2008, 03:34 AM   #3 (permalink)
Re: imrc relocation
I don't recall seeing a post about it before.... but I "mounted" mine to the air filter housing bracket that's attached to the top of the tranny mount. "Mounted" because it's just been zip tied for about 2 years. I have a 3/8" sheet of aluminum that I cut to size to use as an adapter bracket, but I've just never thought about it long enough to finish.
morbid
2000 Contour SVT (black)
morbid is offline
Old 05-30-2008, 06:03 PM   #4 (permalink)
device has been modified
Tygerr's Avatar
Re: imrc relocation
Just mount it somewhere cooler in the engine bay, aka, not on top of the engine block. Hence, somewhere with more airflow.
Also, make sure not to ground out the imrc box. I threaded one of the holes in the imrc and used a bolt to attach it to the old airbox bracket for a "clean" look. In doing such, I grounded out the imrc box, which caused the secondaries to always be open, and in short, fried the motor. I had to buy a new one, and just put it back in the stock mount.
It also allowed me to find out if I ever wanted to "manually" open the secondaries. All I have to do is run a swtich to short the box to ground. I really have no need though.
Buckeye @ heart
06 Legacy 2.5i Limited
Tygerr is offline
Old 05-30-2008, 07:26 PM   #5 (permalink)
Re: imrc relocation
That's weird... it should be grounded the same as if it's mounted on the valve covers.
morbid
morbid is offline
Old 05-30-2008, 08:53 PM   #6 (permalink)
Tygerr's Avatar
Re: imrc relocation
Nope. At least not on my car. Those mounts coming up from the valve covers are isolated from ground. Strangely enough. Go check it.
Buckeye @ heart
Tygerr is offline
Old 05-31-2008, 06:28 PM   #7 (permalink)
Fett's Avatar
Re: imrc relocation
No. That is illegal.
Your aim sucks, you should sit down to pee. - my Wife
Fett is offline
Old 05-31-2008, 06:32 PM   #8 (permalink)
w00t!
ND4SPD's Avatar
Re: imrc relocation
i don't believe it! You're back!!
~Matt~ ND4SPD Army Kommandant
Amanda and I has a penguin!
ND4SPD is offline
Old 05-31-2008, 06:47 PM   #9 (permalink)
Bergie_dark by design's Avatar
Re: imrc relocation
May be illegal but who's gonna looking under your hood to make sure the imrc box is mount on top of the valve covers..
Dark by design-
"2" 1996 Eagle Talon awd tsi - 1999 Mercury Cougar 3L - 2003 Mustang svt Cobra - 2000 Focus zx3 - 1989 240sx silvia - 1997 Eclipse Gs - T - 2002 Bonneville ssei - "2" Vw Jetta Gli - 1988 Corrado G60 -
Bergie_dark by design is offline
Old 05-31-2008, 07:01 PM   #10 (permalink)
SpeedStyle's Avatar
Re: imrc relocation
thanks for the help everyone, ill be relocating tommorow!!
