How much power to turn AC compressor?
Results 1 to 4 of 4
Thread: How much power to turn AC compressor?
    NECO Member NfWiseguy's Avatar
    2007 Aug
    76
    My AC system is entirely leaked out, and I won't have the cash to fix it until the summer, so I'm wondering if it would be in the interest of performance to bypass the compressor with another belt until I can get it fixed.
    About how much power does it sap from the crank to turn the compressor? And I'm going to assume that not all 2.5's came with AC, meaning I wouldn't have a problem finding one.
    NECO Member pwhitelock's Avatar
    2005 Aug
    Middlesbrough (England)
    281
    Re: How much power to turn AC compressor?
    Practically nothing as when the A/C is switched off the pulley disengages from the compressor via a clutch so only the pulley is being spun. So the weight of the pulley from the drive is all you have.
    2.5 V6 SVT Cougar
    That link is NSFW Lifetime Platinum MemberModerator bensenvill's Avatar
    2003 Aug
    Chicago
    14,355
    correct, the cougar was available without A/C and if you look on your hood or strut tower, there is a belt diagram that shows the cougar without A/C. You can go to any autozone Etc, and get the part number for that, so thats real easy.
    and yes, you wont really find any gains on doing that... I did it and didnt notice the slightest difference.
    I just started hemorrhaging blood from the sheer amount of rage that suddenly built up inside me from that comment.
    1994 Lincoln Towncar w/ 112576 CRUSHED
    1996 Contour SE MTX loaded w/ 137179 CRUSHED
    1999 Silver Frost MTX original owner w/ 70500 ALMOST RUNNING
    2009 Honda Fit manual w/ floormats
    2007 Aug
    76
    right right right, i totally forgot about the clutch on the compressor.
    thanks guys.
  1. engine wont turn over, then wipers turn on?
    By TheLastStand1984 in forum Problems
    Last Post: 2010-01-26, 12:33 PM
  2. A/c Compressor
    By happsmack in forum Problems
    Last Post: 2009-02-14, 09:57 AM
  3. AC compressor!!!
    By Ldycgr99 in forum How To's
    Last Post: 2008-06-11, 01:08 PM
  4. Help With A/C Compressor
    By pcperfection in forum Problems
    Last Post: 2006-02-04, 07:20 PM
  5. compressor
    By Kooter in forum Suspension Performance
    Last Post: 2003-07-12, 10:57 PM
