Old 10-01-2007, 10:47 AM   #11 (permalink)
Jorgen's Avatar
Re: Problems with Underdrive PS and Alt pulleys
Well it appears the belt problem was caused by a tensioner issue. I dealt with that but now it seems the alternator is still trying to take a dump on me. I just don't know how long to try and hold out so that when I bring the one off the car to autozone it will forsure test bad and I will get my freebie that comes due to the LLT. If I don't wait long enough it will test good and I will be SOL if I wait too long I will ahve a towing bill to pay and then have a dead alternator for sure.
1999 DT Green V6 MTX Built 8/7/98. She's got a few mods. [My Daily Driver]
2004 Explorer XLT, V6, Auto, 4x4, loaded [Wife's Daily Driver]
1969 Triumph Spitfire MK3 [Toy/Project]
Jorgen is online now
Old 10-03-2007, 03:33 PM   #12 (permalink)
5% Nation of
scott, thanks for updating this issue. I've had similar issues since installing it.
so please expand. what did you do that fixed the tensioner issue?
bensenvill is online now
Old 10-03-2007, 03:37 PM   #13 (permalink)
Jorgen's Avatar
On mine the tensioner was just extremely loose. I pulled the old belt that was shot, found the tensioner still had the spring tentsion too it but the bolt was out probably 3 or 4 full rotations from being tight. So I tightened up the bolt and put the belt back on there. Since then I have driven about 200 miles and I will be pulling the belt again tonight to replace the alternator I plan on checking out the tensioner a bit more this time and see what is going on there. I will update what I find out.
Old 06-17-2008, 07:46 PM   #14 (permalink)
Got turbine on my mind
Updates? I am thinking of installing this...
Old 06-17-2008, 08:01 PM   #15 (permalink)
ironworker's Avatar
I Was Having That Same Problem, Black Rubber Dust All Over The Front Cover And It Was The Bushing In The Tensioner Wearing Out. Got A New One From Autozone And All Better...
ironworker is offline
Old 06-20-2008, 01:56 PM   #16 (permalink)
Swap to a shorter belt if the belt length is an issue with the tensioner.
