My ebay (weapon R) header review with pictures.
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
Thread: My ebay (weapon R) header review with pictures.
  1. #21
    I like whine and TT's Moderator iceberg65's Avatar
    2007 Apr
    Medicine Hat, AB
    3,108
    Re: My ebay (weapon R) header review with pictures.
    Dont believe the vortech kit works on the cougar. we dont have as much room beside the timing belt side of the car as the focus does. I had to get creative with one of my alt bolts because of this with my JRSC.
    The only SC confirmed to fit in a cougar is the Jackson racing supercharger (mine is the svt kit that took modifications to fit) the base kit fits easier and uses a smaller blower. The powerworks SC for a focus "might" fit. But looking at pictures it seems to me that our axle would get in the way of it (mounted higher then on a focus)
    The ONLY Supercharged Zetec Cougar! (C'mon, somebody else do it!)
    00 JRSC 2.0 Cougar
    13 Taurus SHO
    04 Ram 2500 on 35's and 6" long arm
  3. #22
    Hey
    Hey is offline
    NECO Member Hey's Avatar
    2009 May
    Does it matter???
    760
    Well been working on the cougar to get her up and running and about finished decided to take her to the muffler shop to get the exhaust leak fixed. Turns out my weapon r header is cracked right by the 02 sensor. Anyone experience the same thing??
    " When the time comes for the Planet to die, you
    will understand that you know absolutely nothing. "
  4. #23
    NECO Member rooster210's Avatar
    2008 Sep
    Raeford N.C.
    1,839
    just weld the crack and call it good
    99 frosty, Lots of mods done to it.
    black 99, upcoming tinker toy
    99 E150 Econoline coachmen conversion
    2016 Honda Civic EX Turbo
  5. Remove Advertisements
  6. #24
    Hey
    Hey is offline
    2009 May
    Does it matter???
    760
    Quote Originally Posted by rooster210 View Post
    What kind of weld should I be using?? I heard you need a certain kind for stainless steel
  7. #25
    2008 Sep
    Raeford N.C.
    1,839
    I would say probably a tig welder if you have one
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  8. #26
    NECO Member Joeyisamadman's Avatar
    2015 Oct
    Sherbrooke, Québec
    265
    Quote Originally Posted by Hey View Post
    Stainless steel is reactive. you'll need to back-purge it (fill the inside with Argon) before you weld it, or else your weld isn't going to work out. I can't help you on Filler material or settings, I've never welded stainless. but if you had a TIG setup with a Foot pedal and appropriate filler wire, reckon you could keep heat and warpage down. Heck, you might even get away with fusing that thing together.
    food for thought, but most cheaper (I use that term with the utmost respect! ) headers are MIG welded and they work just fine too. so if you've got some skills, as long as you back-purge it, you might get away with it.
    NECO's only French Canadian!
    '00 2.5 ATX, Laser Red: ''Ella'' AKA that Rusty old thing : http://bit.ly/1VfpWlX
    '08 Smart Fortwo: ''Yeah? well My other ride's a Rear wheel drive, rear engined MERCEDES!!!''
  9. #27
    Hey
    Hey is offline
    2009 May
    Does it matter???
    760
    Quote Originally Posted by Joeyisamadman View Post
    great info, definitely something to check out
