Simple. Removing the engine to replace *how to
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: Simple. Removing the engine to replace *how to
    2009 Jan
    6
    Hi.
    I am new to your guys great forum.
    I am replacing a timing belt for a friend on his 1999 Mercury Cougar 2.0
    I exclusively work on v8 engines, rear wheel drive- it is simple design.
    I can do any repair on my Lexus'
    I am very mechanically capable but do need advice
    Clearly there needs to be a thread about how to remove cougar engines.
    I will post pictures and make a tutorial if I can get some advice.
    Moreover to start I am pulling the 2.0 cougar engine from the topside with a picker.
    Does the engine unbolt from the transmission for the removal?
    How is the engine mated with the transmission mechanically?
    Does the engine unbolt from the transmission via the flywheel to a torque converter?
    I cannot determine the best way to remove the engine from the transmission at this point mainly due to lack of information around.
    Lets start with the answers to those questions.
    I know we can make this work collaboratively
    Thanks alot men
    Capital Curmudgeon Lifetime Platinum MemberModerator skater's Avatar
    2003 Aug
    Harwood, MD
    8,244
    Re: Simple. Removing the engine to replace *how to
    But I moved it to the wrong forum!
    1999 Cougar, Laser Red, 3.0L V6, MTX (a lot more fun)
    2014 Ram 2500 Big Horn 6.7L Diesel (Towzilla)
    2012 Honda Accord V6, ATX (daily)
    NECO Member CodyTRX's Avatar
    2007 Oct
    NC
    3,650
    Quote Originally Posted by skater View Post
    Good job Skater!
    Born 02/13/1999. Silver Frost Duratec MTX Sport
  5. Remove Advertisements
  6. #4
    3L Install Maestro Moderator Blackcoog's Avatar
    2000 Oct
    Minneapolis, MN
    7,837
    Moved to 2.0L section....
    In response to the question: I haven't pulled a 2.0L out but I'd bet you pull the engine and transmission out the top together as you do with a 2.5L. I don't recall there being enough room to separate the transmission and engine while in the car.
    Click here to see my Cougar.
  7. #5
    NECO Member brapple's Avatar
    2004 Oct
    Gales Ferry, CT
    2,307
    Quote Originally Posted by Blackcoog View Post
    i looked at the 99 ford cd and they suggest splitting them in the car, iirc
    now one problem with going out the top with them together is there is an ac line that runs over the engine/transmission right where they split.
    - 12 Focus Se Sport 5-spd
    - 99 Contour SE Sport Duratec 5-spd <- traded in
    - 2k Contour SVT - #2137
  8. #6
    Administrator Lifetime Platinum MemberAdministrator wadespencer99's Avatar
    2003 Oct
    Wellsboro, Pa
    15,133
    We split a 2.5 engine and trans once, and it wasn't a lot of fun. Not much help, I know
    1999 Cougar (crushed)
    2000 SVT Contour
    2000 Jeep Wrangler Sport
    2004 F150 FX4 Supercab
    2013 Fiesta Titanium
  9. #7
    TZT Performance Moderator Turbo Zetec Tour's Avatar
    2007 Sep
    Aurora, CO
    3,347
    The Zetec can be split from the trans in the car, i did it when i first pulled the engine in my 97 as i couldnt get the shifter rod apart from the trans.
    im assuming your asking about an ATX car in which case the trans case is bolted to the block and the torque converter is bolted to the flex plate (dont know of a single Auto trans that isnt)
    Daniel - TZT Performance
    2000 Black SVTC #391 - sold
  10. #8
    2003 Aug
    Harwood, MD
    8,244
    Quote Originally Posted by CodyTRX View Post
    Good job Skater!
    I fail at moderation!
  11. #9
    NECO Member 2C0UGAR00's Avatar
    2007 Nov
    In Mooresvile NC
    996
    not much help to begin with but i'll be interested on this how to i plan to take mine out when i move to northcarolina
  12. #10
    NECO Member c0alition's Avatar
    2007 Jun
    Amherst, MA
    952
    are you pulling the engine just to change the timing belt?
    Those who say it cannot be done should not interrupt those who are doing it.
  1. removing engine from top
    By AndrewM6097 in forum General Info
    Last Post: 2010-03-08, 02:15 PM
  2. removing oil pan. Engine mount in the way!
    By John Paul Search in forum Problems
    Last Post: 2008-02-18, 07:48 PM
  3. Replies: 6
    Last Post: 2006-03-22, 10:35 PM
  4. My replace engine light just came on....
    By BMac in forum Problems
    Last Post: 2004-05-23, 03:19 AM
  5. 3 simple questions about engine
    By Bayeri in forum General Info
    Last Post: 2003-07-15, 02:39 AM
